The iPod 4G (fourth generation) is easy to restore to factory settings. This may reinstall the software, and it always wipes all music, video and other data from the iPod. Restoring is the most effective way to fix problems with the iPod that haven't been fixed through traditional troubleshooting. You will not be able to retrieve data from your iPod 4G once it's restored, so make sure you back up your information first.
Plug your iPod 4G into your computer with its dock connector USB cable. Install the most recent version of iTunes and open iTunes. Wait a moment for your iPod to appear in the side bar. Click on your iPod in the side bar and select "Restore." A pop-up window will ask if you're sure you want to clear your iPod and restore to factory settings. Click "Continue" and enter your password, if prompted. Leave the iPod untouched and on a flat surface while it restores to original settings. It's important that you don't try to disconnect or use the iPod while it's restoring. You'll see a progress bar either on the iPod or your computer that indicates how far along the process is. Select your new syncing settings (automatic sync or manual) when prompted after the restore is complete.
SOURCE: My ipod touch 32GB 2nd gen crashes frequently?
The only viable trouble shooting option I have available on this current issue is to restore the ipod touch using itunes. Just in case you are unsure of how to do a restore, I have included step by step instructions below.
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
SOURCE: iPod Touch, 1st gen, "slide to unlock" broken
If you jailbreak (quickpwn.com) there is an app on cydia that will change it to tap to unlock rather than slide so it should be more sensitive.
SOURCE: Ipod Nano 4th gen LCD backlight not working
Its definitely the logic board (motherboard) that has gone bad. Its not the actual screen nor LCD. Its the logic board. You could replace the screen with a new onje and the backlight still will not work. Nano's are known for this but of course apple won't admit to putting out a piece of **** logic board in all of the nano's or they would have to recall 10 million of them! So, they just play stupid and say your nano is out of warranty but we'll give you a 10% trade in discount. What a joke! I know this because i used to work for Apple ;-) They screw customers left and right to keep their profits up.
