Question about Zapco Car Audio & Video
Zapco reference ag 1000 specs
How many channels is the amp also what is the ohm loads and wattage. THANKS ALOT..
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: zapco ag 350
Check your ground and make sure it is properly grounded ....it needs to be a very clean paint/gum free area tightly bolted.  Next Check and make sure you are recieving your 12 volts (not running)  13 (running)    by placing your test leads from positive to ground...... then make sure your power remote from your head unit is putting out voltage.
Posted on Oct 13, 2007
Anonymous
  • 21 Answers
SOURCE: new Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Posted on Jan 27, 2009
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
Joel Friedenberg
  • 1114 Answers
SOURCE: a3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Posted on Jul 22, 2009
    micmor100
    Morne Olivier
    • 257 Answers
    SOURCE: How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
    Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
    Posted on Jun 09, 2010
    I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
    Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
    Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
    Sep 12, 2017 | Pyramid Car Audio & Video
    Can I bridge my 1200watt 2channel sony xplod amplifier?
    How many ohms at two channels, remenber ohms law, amp should be stable at lower ohm RMS wattage..whenn you say 1200 watts its that full wattage, now you got a RMS wattage..What is it?
    Apr 04, 2016 | Sony Car Audio & Video
    How do i wire my kicker dcvr122 up to a 4 ohm amp
    I am going to assume the 2 speakers in the sub are each 4 ohm loads, and are wired together in parallel, creating a 2 ohm load. And your amp pushes 800W at a 2 ohm load. And actually goes down to 1 ohm/1100W. Anyway...
    Seems you want to lessen the wattage output of the amp by making a 4 ohm load. To do that, you need to wire the both 2 ohm speakers in SERIES.
    In general wiring principles, to wire in SERIES, take the POS terminal from the amp and wire to the POS terminal of first speaker. Take the NEG terminal from the amp and wire to the 2nd speakers' NEG terminal. Then place a "jumper" piece of speaker wire to connect 1st speakers' NEG terminal to 2nd speakers' POS terminal. Now you have a 4 ohm load, and will be pushing 450W from your amp.
    This way the load will now be 4 ohms.
    Jan 08, 2013 | Kicker DCVR122 -- 2 Ohm Dual 12in CompVR...
    I have a 10.2 Orion Hcca subwoofer 4 ohm and wanted to know if I can put each coil to each channel its a Brutus 1200 watt 2 channel amp model 1210d is it safe for my woofer and how much rms wattage I'm...
    You would need to know what power your amplifier supplies at 4 ohms. In reality, you would be better off bridging the amplifer and wiring your sub in parallel to a 2 ohm load. This would allow you to pull the most power out of the amplifier. It would be safe to do a voice coil to each channel on a 2 channel amp. However, if you happen to have a 4 voice coil sub and attempted to put two 2 channel amps to it, you would have to make sure your amps are leveled. No easy feat. The variance you could have with that could damage the voice coils. But luckily, that's not your case.
    Sep 09, 2011 | Orion HCCA 10.2 Car Subwoofer
    Wattage
    I have the following specs for you
    Basically 150watts per channel using two channels , or 75watts using all four
    Here goes:
    • 4 Channel Mosfet Amplifier
    • Advanced Overload and Thermal Protection
    • Metal Film Capacitors/Resistors In Signal Path
    • Frequency Response +/-1dB, 20Hz to 20 kHZ
    • Signal to Noise Ratio (A-weighted) >100dB
    • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
    • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
    • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
    • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
    • Minimum Load when Bridged 2 Ohms
    • Minimum Load per Channel 1 Ohm
    • Input Signal Voltage Range 0.1 volts to 2 volts
    • Crossover Type Resisitor Network, Linkwitz Riley,
    • Highpass/Lowpass
    • Crossover Slope 24 dB per octave
    • Crossover Frequency Range 20-550Hz
    • Factory Crossover Setting 85 Hz
    • Auxilary Output Channels 2
    • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
    • Bass Boost 0- to +18dB @ 45 hZ
    • Power Supply Voltage 10Vdc to 15.5Vdc
    • Recommended Fuse 40 amp
    Dimensions 12.25L x 9.25W x 2.10H
    May 23, 2010 | Car Audio & Video
    I want a reliable system.
    if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
    May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
    Can you tell the wattage of the onkyo tx 905 not the home theatre model stero only
    140 watts minimum continuous power per channel, 8 ohm
    loads, 2 channels driven from 20 Hz to 20 kHz, with a
    maximum total harmonic distortion of 0.05% (FTC)
    170 watts minimum continuous power per channel, 8 ohm
    loads, 2 channels driven at 1 kHz, with a maximum total
    harmonic distortion of 0.7% (FTC)
    180 watts minimum continuous power per channel, 6 ohm
    harmonic distortion of 0.1% (FTC)
    Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
    How to bridge a punch 3001 car amp
    You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
    Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
    Help on 1 amp and 1 alpine srw-124d
    You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
    now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
    connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
    Series = add the two ohm value
    parallel= halve the ohm value
    you can play with series and parallel together using more than one speaker setup.
    Jun 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    My vibe 286 4000 watt lanzar amp wont stay on..
    Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
    Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
    Car Audio & Video Logo
    224 people viewed this question
    Top Zapco Car Audio & Video Experts
    Marvin
    Marvin
    Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
