My 1994 eagle talon is not starting up! i checked the spark plugs it was working perfectly fine! the fuel injecters working fine too. it is not starting up. what do i do?
1990 4 cyl. auto Eagle Talon- While driving down the highway it just up and quit on me. It turns over strong, is getting gas (plugs are wet), and has spark but it won't fire. Did you find your problem? 1990 4 cyl. auto Eagle Talon- While driving down the highway it just up and quit on me. It turns over strong, is getting gas (plugs are wet), and has spark but it won't fire. Did you find your problem?
You can't post conmments that contain an email address.
I would check the coil or, distributor unit and wires then, i would also check the battery for weakness. if the batt is fine, check the starter and wires that lead to the starter as well. sometimes the starter wires can jiggle themselves loss at times. hope that helps ya and thx for using fixya:)
I would try making sure spark plug wires are put on in the correct firing order. This is a common mistake in tune ups. Most intake manifolds have the firinging order cast in. Plug gaps correct? I cant come too far away.
make sure the timing belt hasnt broken.they can break at anytime when old and usually break when decellerating [spelling wrong] or when turning off engine.
you got fuel and spark, check the third to the equation, air... maybe you have an obstruction, also if you have a compression guage check the compression. good luck ill check back.
