Question about M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
Pinout in the m-audio delta 1010 - M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
3 Related Answers
Anonymous
SOURCE: Using drum triggers with M Audio Delta 1010 and Digidesign MP 7.3
This site is useless. I posted this problem awhile back and nothing is posted for it. Don't waste your time here.
Posted on May 24, 2008
Anonymous
SOURCE: M-Audio Delta 1010 PCI CARD
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Posted on Jun 21, 2008
Anonymous
  • 268 Answers
SOURCE: m audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Posted on Oct 06, 2008
Why isn't it being detected by my win 8 ?
Try reinstalling the Audio Driver As windows 8 drivers are not available Reinstall the windows 7 driver
http://www.m-audio.com/support/download/drivers/delta-6.0.8
May 12, 2016 | M-Audio M Audio Delta 1010 Lt Sound Card
Sound drives free download now
Drivers for that sound card can be downloaded from M-Audio's support site linked below.
http://www.m-audio.com/index.php?do=support&tab=driver
Choose Delta Series Card>Delta 1010>Select OS and you should be able to download the drivers.
Robert from Blitware
Jun 17, 2010 | M-Audio Delta 1010 PCI CARD Sound Editing...
Where can i get a free M-audio 1010 to download?
You can download the Delta 1010 drivers from the website http://www.m-audio.com/index.php?do=support.drivers&f=736
I hope this works for you :)
Regards,
Aby
Apr 21, 2010 | M-Audio Delta 1010 Sound Card
Popping and clicking in delta 1010 playback
frequency response: 20Hz-22kHz, +/-0.3dB spacer.gif dynamic range (A-weighted): 109dB (A/D), 117dB (D/A) spacer.gif signal-to-noise ratio (A-weighted): -109 dB (A/D), -117dB (D/A)
I found these on the site, seems you have the khz way too high.
All good.
Here's the link to your site.
Jul 22, 2009 | M-Audio Delta 1010 Sound Card
Hearing double voice when monitoring through delta 1010
Check to see if you have your onboard sound turned on. If you do turn it off and this should stop the double voice.
Jan 07, 2009 | M-Audio Delta 1010 Sound Card
M audio sound cards
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
Jun 17, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
May 14, 2008 | M-Audio Delta 1010 Sound Card
Clicks
try to change the clock sync in the sound card to independent
Mar 26, 2008 | M-Audio Delta 1010 Sound Card
Delta1010 on Hacintosh
WORKING DRIVER HERE FOR M-audio PCI:
 M-Audio Delta 44 (verified)
 M-Audio Delta 66 (verified)
 M-Audio Delta 410 (verified)
 M-Audio Delta 2496 (verified)
 M-Audio Delta 1010 (works for some)
 M-Audio Delta 1010LT (verified)
 Terratec Phase 88 / EWS88MT / TS88PCI (tested only on EWS88MT)
 Terratec EWX2496
I tested on my M-audio Delta 1010 with box today and everything incl. SPDIF is working great on my osx86 v_7 10.5.8 system! The only thing not working is midi as told on website. Im submitting file for the above sound cards! Dont Forget to donate some money to this guy!!!
http://www.audio-evolution.com/drivers/
http://www.insanelymac.com/forum/lofiversi...t25145-150.html
Mar 22, 2008 | M-Audio Delta 1010 Sound Card
M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
263 people viewed this question
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
Gustavo Ortiz
Gustavo Ortiz
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
