Samsung BD-P4600  Blu-Ray Player Logo
Brandon Posted on Feb 10, 2013
How do I eject a stuck disc?
It simply won't eject.
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Dvd drive won't open
Might have a stuck disc. Use a straightened paper clip in small pin hole of the CD drive to manually eject.
Magazine won't eject?
On my Mitsubishi 6-cd changer it won't load cd goes in and out 3times but spots it out
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
DVD won!t EJect at all
The DVD might be stuck in the disc tray for whatever reason. To get it out, you could remove all the screws on the back and bottom. Slide out the cover to retrieve the DVD. Plug it in to see if it still works. If it still appears to be working, put it back together and hope that future DVDs won't get stuck.
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
I have a 2007 Honda Odyssey with the built-in DVD player. Now there's a DVD stuck in it, it won't play and it won't eject. Help!
if you look closely enough there is a small hole on almost any sound system if you do have one put a paper clip in there and wiggle it around a little bit youll hear a click and the system should eject the cd if not then the cd has jammed in there and shattered which means you will have to pay a profecional to take out the dvd and get the disc out. hope this helps and if not well i apologise
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
