Question about Crate Music
Shematic diagram korg pa80
Schematic
2 Related Answers
John McPherson
  • 1212 Answers
SOURCE: I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Posted on Mar 30, 2012
samir_keyboa
Samir Khamo
i have korg pa80 its blank screen only lights on for the screen what is the problem
Posted on Mar 21, 2013
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
Mar 29, 2012 | Music
Older peavy 4 string bass with batteries need wiring shematics
I think posting the wiring schematics is not legal. If it just does not work anymore you could try and look if the battery clip is oxidized and try to clean it.
Feb 27, 2011 | Peavey Millennium Bxp 4String Bass Guitar
Hi my keyboard problem some time the screen turn on normaly and some time not i have to turn it of again how can i fix it tnx
It is possible that there iis a compnent failure in teh POR (Power-on-reset) circuit. This is NOT DIY unless you are adept at electronics. I do NOT have the shematic for this keyboard. I looked at the schematic for a PA500 which MAY be similar and it has a touch screen. SOMETIMES dirt gets under the edge of a touch screens and confuses the processor with a false input. If yours fits this scenariom you might try running a piece of copy paper under the edge where the case hits the LCD screen.
Jan 03, 2011 | Korg Pa800 Synthesizer
Sounds terrible , somebody puts his hand over and changes the circuit. i need the shematics please
I might be able to help with the schematics; I have many old Peavey schematics from my tech days. Send me a model number & I'll see what I can do.
Dec 04, 2009 | Peavey Music
Music Logo
90 people viewed this question
Top Crate Music Experts
Ngoro
ray gallant
Are you a Crate Music Expert? Answer questions, earn points and help others
