Tablets & eReaders Logo
Anonymous Posted on Feb 10, 2013
Touchscreen driver I have install windows 8 in my computer. I need to install touchscreen and pen driver. I've look without sucess. I've seen at the hp website and the olny drivers they have is for windows xp, 2000 and vista. Can you help me with this? Thank you
elec_tech
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Feb 10, 2013
elec_tech
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
11
Helped
345
Points
6
You need to find out what Co. made the touchscreen for that model to see if they have updated touchscreen drivers for windows 8.
Sounds like your machine was intended for XP,
  • Anonymous Feb 10, 2013
    thank you for your help. i have already made the thouchscreen work and also the pen.
3 Related Answers
Anonymous
  • 10 Answers
  • Posted on Sep 29, 2009
SOURCE: my touchscreen dont work after re-install windows xp.
Here is a link to touchscreen drivers and instructions:
http://toughbookcentral.com/once-and-for-all-toughbook-touchscreen-driver
Also there you can find other drivers for CF-18.
Anonymous
  • 53 Answers
  • Posted on Jun 05, 2008
SOURCE: toshiba satellite R15 touchscreen driver
Hi , if you have WIn XP or XP SP2 click on the link below to download the touch pad drivers for Satellite R15-S822.
If you are using Vista then you will have to Manually selct Wondows Vista from the drop down box on the page.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=872584&moid=882875&rpn=PSR10U&BV_SessionID=@@@@1278931486.1212681927@@@@&BV_EngineID=ccchadeefjhhhdecgfkceghdgngdgmm.0&ct=DL&all_docs=false
Anonymous
  • 193 Answers
  • Posted on Aug 18, 2009
SOURCE: touchscreen/pen not working for Toshiba Protege M400
all available drivers for the m400 series can be found here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click on downloads, then select your exact model
Need to reset a digiland dl808w tablet NO TOUCHSCREEN
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Touchscreen not working
You just need to download and install the driver and it should be fine.
Go to www.hp.com and click on support and drivers then check the download drivers button and finally enter in the model in your case TC4200 and this will open a new page. Next select your operating system and you are now at the downloads page.
Download the drivers, save to desktop (its easy to find again then) and then run it and folow the inscreen instructions and reboot if asked to.
You haven't mentioned your operating system so I can't give you any more exact instructions. If you download and install all of the available drivers for your version of windows you can't go wrong. Windows will try to use built in drivers such as the video. These work but the oem driver usually gives you more options and sometimes better performance. The touch driver will either be part of the video or the input drivers dpending on what version of windows.
1helpful
Touchscreen has stopped working on the tablet I
its a software problem try reinstalling the software
6helpful
2answers
My Toughbook CF-18's touchscreen stopped working. Do I need a driver? If so, can someone send me one? [email protected]
Download the touchscreen driver from the Panasonic site.
Go to Start > Control Panel > System
Click the hardware tab.
Click the device manager tab.
In device manager click on Mice and other poiting devices
Select the touchscreen with left click and click the unistall option.
Once done close all windows and install again using the downloaded file from Panasonic.
4helpful
3answers
2helpful
2answers
My touchscreen dont work after re-install windows xp.
try looking on the restore discs for drivers, use the explore option after you right click the cd with disc loaded if not there then go to mfg's website and try looking under support /downloads. you didn't mention model or make, the drivers are on the website in any case. you will get most current drivers from there. hope this helps. good luck
3answers
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Fujitsu p1120 touchscreen not working
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
