Question about Radio Communications
I need to know the value of the capacitors at C4 and C5 thank you
Posted by Alfred Santee on
Garett
    New Friend:
  • 4 Answers
Hi there, im assuming you have the ARF 2001 scanning/transceiver.
I found your print and C4 is 1000 and C5 is 1000.
Example: capacitor 101, it is measuerd at micro (uf) and picofrads (pf) therefor this is calculated at 0.001 (uf), 1000 (pf).
The answer to your question is capacitor code for C4 & C5 is 1000.
0.0001 (uf) or 1000 (pf).
I hope this helps.
Posted on Feb 10, 2013
  • 3 more comments
  • Alfred Santee
    Alfred Santee Feb 10, 2013
    Thanks I believe you are. Protect. I thought that myself but then the shadow of doubt crept in. I assing the are radial caps what is you opinion on that
  • Alfred Santee
    Correct I meant to say and I am assuming they are radial caps
  • Alfred Santee
    What voltage are they?
  • Garett Feb 11, 2013
    The voltage for 1000 uf capacitor can range from 10-50 volts and up! depending on what type of casing and application.The alum, casing can store up to 5 times is voltage and has an output of 20Amps.Example:Electrolytic Decoupling Capacitors - 1000uF/25VAluminum Capacitor, Radial - 1,000uF 10V Can you tell me the exact electronic unit were talking about and it's application? can you send me a pic of the caps
  • Alfred Santee
    Alfred Santee Feb 11, 2013
    Are they 1000uf or 1000pf?
Indesit IDC75 dryer need to know all the order in wiring on front panel timer,start,etcetera
The spade terminal wiring sequence for the timer is: White/Black to B5 // Pink/Black to A2 // Gray to A3 // Single Blue to B1 // Double Blue to B2 // Single Red to C5 // Single Black to C4.
Oct 18, 2014 | Dryers
How solve the problem to enter 13.5% tax rates to tally
Spread sheet ...your total = 13.5% correct???
Sum the col or row lets call it r5 c4. go to r6 c5 and enter "= r5 c5 * 13.5%"
Go to r7 c5 and sum r5 c5 + r6 c5.
Thnks for your quesiton at FixYa.com
Nov 23, 2010 | Health & Beauty
I need help in locating the capacitor on element 32"lcd model elcpo321
There are many capacitors on a tv. If you are looking for a specific one, please let me know. One with a top bulging is usually indication of needing to be replaced. Otherwise let me know your more specific question. thanks Benjamin
Feb 24, 2010 | Televison & Video
Need 5c01 ex cw starview
C & W 5C 01] 08/10/09
00 = C5 BE AF 36 0A 61 91 AA
01 = D2 D1 80 FA 21 85 0F 53
Telewest 5A01 08/10/09
00 = 83 5D12 B8 96 F6 1F C4
01 = D2 F9 3F 22 0C A7 D6 C9
NTL 54 01] 08/10/09
00 = F0 0E 91 E0 2D C1 C5 FD
01 = 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Telewest Codes 08/10/09
NTL 54 01] 08/10/09
Eurovox code
The new code for 5A01 from the 6th October is :-
KEY 00 = C2 B5 BE 41 0D 9B C5 7C KEY 01 = 6D EA 8E 97 6A AA DA 71
Please dont forget to leave your nice feedback. Thanks
Oct 05, 2009 | Televison & Video
Excel radom selection formula not working
What are the values of cells C4 and C5? Should the function above be "...RANDBETWEEN(A$4,A$5)" ?
Jun 29, 2009 | Microsoft Office Excel 2003 for PC
Formular to show number and cell references
The formula for A1 is: =SUM(B4,B5)
A2 is: =SUM(C4,C5)
A3 is: =SUM(A1:A2)
To test this, put 25 in cell B4, 25 in cell B5, then 30 in cell C4, and 30 in cell C5.....the result in cell A3 is 110.
Hope this helps.
Mar 07, 2008 | Microsoft Excel for PC
Using if and then to add values to a cell
Try using the SUMIF function for one condition or multiple conditions. Use the SUMIF worksheet function to create a total value for one range based on a value in another range. For example, for every cell in the rage B5:B25 that contains the value "Northwind", the following formula calculates the total for the corresponding cells in the range F5:F25. Formula:
=sumif(B5:B25,"Northwind",F5:F25)
Here are SUMIF functions for multiple conditions.
=sum(if((B5:B25="Northwind")*(C5:C25="Western"),F5:F25))
=sum(if((B5:B25="Northwind")+(C5:C25="Western"),F5:F25))
=sum(if(B5:B25="Northwind",IF(C5:C25="Western"),1,0)))
Also check your help for SUMIF functions.
If this helps you, Please rate me. Thanks, Patty
Dec 09, 2007 | Computers & Internet
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
