Question about Princeton Digital Computers & Internet
Monitor Goes Black
Turn on monitor and it goes black off after 3 seconds...it makes a hiss, then a click when the screen goes blank.
Posted by D Rama on
Eric
    Sergeant:
  • 378 Answers
There is a blown capacitor on one of the boards inside display
Posted on Feb 10, 2013
  • D Rama Mar 02, 2013
    Even if I replace the capacitor, what would prevent it from recurring?
5 Related Answers
Anonymous
SOURCE: Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Posted on Oct 17, 2006
Anonymous
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
Posted on Jul 17, 2008
bammbammfran
Fran Bednar
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
Jeff Orthober
  • 60 Answers
SOURCE: starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Posted on Mar 26, 2009
Anonymous
  • 79 Answers
SOURCE: SCREEN GOES BLACK AFTER A FEW SECONDS AFTER TURNING MONITOR ON.
More often then not, this is attributed to a failing Backlight Inverter. A Backlight Inverter, is a power board mounted below the screen that actually send power to the Lamp inside the LCD itself. Check to see, when it goes out if there isn't still some images faint in the screen. If this is the case take it to a local repair shop and have them order one and replace it. repair cost for this shuold be around 65-100 dollars.
If this helps, please rate my solution. Have a great day.
Posted on May 16, 2009
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor going black
may you just uninstall the first video card driver & monitor driver, & then install it again..
please post back & let us know here, how things done..
Thank you
May 02, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
142 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
