Question about Panasonic SV-AV50S Digital Camera
Cant find a SD-MovieStage.exe program to read my sd card
In order to read my panasonic sd card I need the SD-MovieStage.exe program, is that true?
6ya staff
SOURCE:
Jrussell789
  • 172 Answers
SOURCE: Panasonic Lumix DMC-FZ20 SD Card Reading Issue
Plug you camera into USB. Go to My Computer and find a drive device named External Drive or USB Storage etc. Click on this and you should see a folder named DCIM (digital camera EXIF standard Digital Camera IMage folder. This is your cameras memory card.
Click on this and find a subfolder(s) named according to manufacture. For Panasonic it would be 100_PANA or maybe 101_PANA. These are you picture folders. Click on one to find pictures. Drag and Drop folder to computer to download them.
Posted on May 16, 2008
Anonymous
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
Posted on Jul 05, 2009
Anonymous
SOURCE: Can I use a SDHC card in my Panasonic DMC-TZ1
According to the TZ1 manual the maximum size of SD hard is 2gb. You cannot use the new format SDHC card as it is not recognized.
Posted on Dec 05, 2009
Dennis Maeder
  • 257 Answers
SOURCE: None of my SD cards (I have 4) will work with my panasonic lumix
This camera uses the SD standard - not SD HC.
Be sure you are using a compatible card!
The highest capacity mentioned in the manual is 1GB althought the SD stanard supports up to 4GB.
Posted on Dec 14, 2009
LongPockets
LongPockets
  • 1177 Answers
SOURCE: Is there a maximum SD
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Posted on Dec 09, 2010
Testimonial: "Cheers long pockets I really appreciate your prompt reply and clarification. Sorry about the MB- GB thing,I will go for a 1GB and back card - thanks"
I scanned my micro sd 1gb and 2gb cards with wormblaster and now the 1 gb reads 59mb and the 2gb reads 13mb and will not format does these cards have a MBR that maybe got wiped from the scan because both...
Instructions
Things You'll Need:
* SD card slot or card reader
1. Download SanDisk Formatting Utility
2. Open an internet browser and enter the URL for the free SanDisk formatting utility into the address bar (see Resources).
3. Accept the terms of use by clicking the button labeled "I Accept" at the bottom of the page.
4. Save the executable installation file (sdfv2000.exe) to the computer hard drive.
5. Open Windows Explorer and navigate to the installation file.
6. Double-click the sdfv2000.exe file to begin the installation of the software.
7. Click "Yes" to accept the terms of use for the installation package.
8. Verify the installation location and click "Next."
9. Select a Program Folder for installation and click "Next." The progress bar will monitor the installation.
10. Click "Finish." A text file containing notes for formatting software will automatically open.
Format SanDisk
11. Click the Windows "Start" button.
12. Click "All Programs."
13. Locate and expand the Panasonic link.
14. Double-click the program entitled "SD Formatter."
15. Insert the SanDisk card into the SD slot or card reader.
16. Click the top drop-down box in the SD Formatter interface to view a list of available drives on the computer.
17. Locate the SanDisk drive and select from the drop-down options.
Click the button labeled "Format" to begin the formatting process. A notification will appear to indicate the process has finished.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
Sandisk Micro SD Card stops after 108 songs
If you formatted the card first, you should have had a true value of the Size.
Even a true 1 Gig card, only has a capacity of 960mb.
As the card has to allow for a valid boot-block to be written to it.
This is so the read/write device, can recognise the drive/cards format i.e FAT/FAT 32 et,c.
I,d suggest that you have a 512mb card, that has a 1 gig sticker on it.
The chinese have a way of doing this with MP4 Players. they sell them as 4 gig, when you format them, they,re actually 1 gig or smaller sometimes.
I,d suggest backing up yhe card, and formatting it, to see it,s true size. And that your also using the correct Format.
Mike @ compurepair.
Mar 14, 2008 | Electronics - Others
Software
SV-AV25 & SV-AV50- SD Jukebox Ver. 4.0, SD Moviestage Ver. 2.5, USB Driver SV-AV100- MediaStage, USB Driver SV-AS10- SD Jukebox Ver. 4.0, SD Viewer Ver. 2.1, USB Driver
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
Software
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
Software
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
Software
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
Software
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Software
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
SD Memory Card
The data on the SD Memory Card can be broken up into five separate folders (where applicable): [DCIM]: The images in this folder (e.g. IMGA0001.JPG) are recorded in the JPEG format. [MISC]: Files in which DPOF Data has been set to the image are in this folder. Slide show data created by SD-MovieStage Ver. 2.5 are also stored in this folder (e.g. AUTPLY0.MRK). [SD_AUDIO]: Stores music data files (e.g. AOB001.SA1) recorded by the SD-Jukebox Ver.4. [SD_VIDEO]: MPEG4 moving pictures are recorded in ASF format (e.g. MOL001.ASF). It can be played back with Windows Media Player 6.4 or later. [SD_VOICE]: Folder in which voice data files (e.g. MOB001.VM1) are stored.
Aug 31, 2005 | Panasonic D-Snap SV-AS3 Digital Camera
Panasonic SV-AV50S Digital Camera Logo
27 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
