SOURCE: Kenmore Oasis HE won't drain
I had the exact same problem last night.
Here is what I did and it fixed it with NO PARTS or SERVICE CALL.
First, I took the drain hose and Blew through it with my mouth... I got air bubbles to come up in the wash bason, this told me the drain pump and hoses were not "Clogged"..
Next I took a shop vac and a 5 gallon bucket and used the vac to **** on the drain hose to start a siphon into the bucket...worked like a champ... I had it drained in less than 3 mins....
I Took the back cover off and then the drain pump off and took the 4-5 screws out of the mounting bracket and took the pump cover off.
What i found when I did this was that there was a VERY SMALL FLAT ROCK stuck between the impellor and the pump casing.
WIth a small screw driver I flicked out the rock and the impellor was free again... HOWEVER, When you do this, the impellor will turn half way and stop... half way and stop, half way and stop...etc.........IT WILL NOT SPIN FREELY like a top. When the motor is still attached to the pump, the armiture in the motor still gives reisitance to the impellor...This I PRESUME this to be normal..
I ended up putting it ALL back together except the back cover to test it...I turned it to a wash cycle and let it run for a few mins. Then i hit stop twice to cancel that wash request. Then i started a second wash cycle and the drain pump kicked right on to drain the water left in the basin from the first test wash..... So far she's purring like a kitten..... Fingers Crossed of course...
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
SOURCE: Stops before spin with error code of LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
