Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
James Anderson Posted on Feb 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transformer is not turning on
It does not click when timer is set
Gene Haynes
Level 3:
  • Malibu Master 5,391 Answers
  • Posted on Feb 10, 2013
Gene Haynes
Malibu Master
Level 3:
Answers
5391
Questions
0
Helped
2603948
Points
14124
1) Copy following link for malibu replacement trippers, troubleshoot overview, tips, and warranty information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) After reading information on link above, add a comment and describe which transformer you have, and if this is new installation, or older installation that worked before.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Timer on transformer reaches to on, but stops there. When I turn past it, timer goes to off, but wont go past that.
Clock motor is bad. Set to auto and plug transformer into ordinary plug-in timer.
Troubleshoot on following link:
How to fix timer on electronic transformer
Set transformer to ON. Then plug transformer into cheap wall timer
Gene
Describe your Malibu 600W Power Pack Transformer Problem When it is time for the low voltage lights to come on the timer can not get past the pin to turn it on, however when I turn the timer dial it...
When dial gets stuck at tripper, then clock motor has gotten weak.
1) Some people report taking apart the clock motor, cleaning gears, and adding vaseline to gears.
-Some people write and ask how to put gears back together after taking timer apart.
-Some people find the gears are stripped.
-There are no replacement clock motors or timer modules for Malibu/Intermatic timers.
2) Easiest solution might be to buy cheap plug in timer, set power pack to override, then plug power pack into cheap timer.
3) Power packs come with a warranty, but warranty requires sales receipt.
-Open following link for resources including warranty.
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Malibu Model: ML200TW Transformer Automatic timer not working
You can buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
I wrote power pack troubleshoot checklist:
http://www.fixya.com/support/r8391011-power_pack_not_working
1helpful
Timer stops at on and off trips and doesn't turn on or off
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
ML900wTW transformer gets stuck at the "on" position and stays there. Lights wont come on,unless I advance the wheel manualy. Then the clip will turn the lights on. The lights have no problem turning...
Top Malibu Hardware & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
