Akai PDP42Z5TA 42 in. Plasma Television Logo
OSWELL Posted on Feb 09, 2013
Akai PDP42Z5TA 42 in. Plasma Television remote codes
5 Related Answers
Anonymous
  • 298 Answers
  • Posted on Apr 16, 2008
SOURCE: help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Anonymous
  • 8 Answers
  • Posted on Jul 12, 2008
SOURCE: Akai 42 inch plasma
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Anonymous
  • Posted on Nov 25, 2008
SOURCE: Akai Plasma PDP42Z5TA - removing base stand
thank you!!
Anonymous
  • 21 Answers
  • Posted on Dec 01, 2008
SOURCE: Akai PDP42Z5TA 42 in. Plasma base removal
Remove 6 scow.
Anonymous
  • 140 Answers
  • Posted on Dec 16, 2008
Back of an Akai PDP42Z5TA showing where the Power board is.
1helpful
Akai PDP42Z5TA turns on but dark screen, no sound, keypad/remote cannot change and cannot turn off. Whats wrong?
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
2helpful
Can you buy parts anywhere for the Akai TV's? I have a 42" plasma that needs a new mother board. Please help!
Rather than ebay or Akai directly, i would order parts from :-
http://www.shopjimmy.com
Thanks.
Problem with remote control
have the remote checked by an authorized servicer they may be able to fix it. if not order a new remote.
2helpful
Akai PDP42Z5TA
Akai 42 plasma controller can not be programed tried every code
i just had this same problem with my 42" akai plasma and after getting no help no where i finally figured it out on my own. The model i have is a PDP42Z5TA but my guess it will work with yours also.if your remote is like mine there should be a "set" button somewhere up at the the top.hold this down till the "tv" button goes solid red. with the tv on or off keep pressing the power button till the tv turns on or off( dont go too fast) or you can pass it up easily cause when the tv does turn on or off you have to hit enter to lock it in.
Akai PDP42Z5TA settings
You have to go menu and do default .
Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
