The power cord is in working order, I have tested it on another electrical appliance. I need to know why the printer will not turn on. It has an internal power modual. Could this be the problem and if it is how do I get it fixed.
SOURCE: PSC 2210 Scanner Doesn't Work
I'm not sure about this specific model, but I've had similar problems with other HP all-in-ones and usually what fixes it is uninstalling and reinstalling the software (make sure to follow their directions properly and not plug the printer in until they tell you to). You should also make sure you're using the most updated software from the HP website rather than the one that came on the CD with the printer which may be outdated.
SOURCE: HP PSC 2210 All-In-One InkJet Printer Start Up Problem
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
SOURCE: power cord installation
Power cord receptacle is on the right side of the "Protrusion" on the rear of the machine (as you look at it from the back). I assume you are missing the cord? It should be a standard power cord like on your PC - you can tell by comparing them.
If you're still confused, go here and download the "setup poster":
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
*Please rate me :)
SOURCE: can't find power cord location on back of hp psc 2210 all in one
http://h10032.www1.hp.com/ctg/Manual/bpu05073.pdf
Warning, PDF.
SOURCE: Dead PSC 2210 - can't get print cartridges out!
Try connecting the printer directly to wall instead of surge protector and see if tha resolve the issue
