Pool & Spa Logo
mark mcclurr Posted on Feb 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
US Parts Center
Level 3:
  • Master 719 Answers
  • Posted on Feb 10, 2013
US Parts Center
Master
Level 3:
Answers
719
Questions
0
Helped
284325
Points
1972
If the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
  • mark mcclurr Feb 11, 2013
    I have replace the heater assembly. It came with new sensors. Have not seen any error codes in spa side display.
5 Related Answers
Anonymous
  • 990 Answers
  • Posted on Jan 20, 2010
SOURCE: Spa Heater
You need to check your temp sensor and your high limit. Both are tubes that slide into the plumbing on or near your heater. If this is a tube heater then they are probally at on each end of the heater and will have small wires coming from them that go back to the control board. Farely common problem and easy enough to fix with replaceing them both. A number of models wire them together so they come as one part. Good luck.
Anonymous
  • 160 Answers
  • Posted on Oct 12, 2009
SOURCE: my spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Anonymous
  • 990 Answers
  • Posted on Nov 27, 2009
SOURCE: heater working but will not heat spa past 80deg
If you have an external by-pass on the pipeing going into the heater you will need to close this down almost all the way (80-90%) if not you have trouble with the internal by-pass. This is inside your manifold on the heater and is letting to much water go past the heater and will need to be replaced. Good luck
A Miller
  • 8404 Answers
  • Posted on May 16, 2010
SOURCE: Need manual for Leisure Bay spa
Go here http://www.spasbyleisurebay.com/ and click on Spa Manuals.
Anonymous
  • Posted on Jul 16, 2011
SOURCE: I have a leisure bay spa with a s pack 3000
i have a s-pack 3000 that has no display ? so do i need a top side or a new pack??
1helpful
Leisure Bay -My spa will not heat - no FLC/FLO code/Voltage is correct/4KW Dry Element Heater test 15.9 Ohm across leads and OL on each to housing
It appears per your test that the heater May not be the problem as it shows that it may be good.
Your error message is a Flow condition / Restriction
Try cleaning the filter
Nov 09, 2014 • Pool & Spa
How long should a 2007 eclipse spa take to heat up??
Usually spas heat approx 5 degrees an hour. If its been a day or so and your water isn't up to heat, you probably need a new heating element in your spa. Check the voltage at your heating element, and on your topside there is usually a heat indicator light that should be lit. If it has correct voltage at heater and the indicator light is lit, heater burned up. If you have incorrect voltage at heater check fuses for a possible blown fuse and see which pump it goes to, that could be your problem.
Mar 09, 2014 • Pool & Spa
My leisure bay spa will not heat past 86 degrees.
If your spa will not heat up to the 104 degrees or what temperature you set it at then you have a bad temp sensor.
RodUS Parts Center888-521-6183
Feb 09, 2013 • Pool & Spa
2answers
I have a leisure bay spa with a s pack 3000 processor 3 pumps system will not heat keeps flashing oh is this a heating element problem how can i repair
I had the same problem with mine! I called Spa Depot at: 1-800-823-3638 and they helped me solve it. Turns out I needed to replace my high limit switch. They walked me through it and had the best price I could find.
-James
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
