Question about Dell Computers & Internet
Dell optiplex gx280 says "dvd is not compatible"
I wanted to "burn" a converted dvd file and it keeps saing the disc is not compatible?
Posted by James J Kurczewski on
Eric
    Sergeant:
  • 378 Answers
Disc r-.r+
Posted on Feb 11, 2013
5 Related Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Posted on Nov 16, 2008
jose_v17
Jose Velazquez
  • 229 Answers
SOURCE: Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Posted on Mar 24, 2009
Anonymous
  • 16 Answers
SOURCE: Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Posted on Jun 11, 2009
Anonymous
  • 8 Answers
SOURCE: dell optiplex gx280 makes loud fan sound at
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Posted on Jun 12, 2009
Anonymous
SOURCE: No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Posted on May 21, 2010
My Dell gx 280 keeps saving that i'm missing a ntldr, how can I fix this problem
Start the pc with your rescue disc as there is a boot file error. When you get it started, in safe mode, run CHKDSK/F to find the error and attempt to fix it.
Feb 07, 2011 | Dell OptiPlex GX280 PC Desktop
Need gx 280 ethernet controller offline computer. disc ?
just download the driver at http://suppport.dell.com
put in the optiplex gx280 model and download the network driver to a usb device or burn to cd etc. Unzip if necessary and put media in desired computer and install
Nov 08, 2009 | Dell OptiPlex GX280 PC Desktop
Good Luck
Jun 10, 2009 | Dell OptiPlex GX280 PC Desktop
Open Questions:
Computers & Internet Logo
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
