Epson L210 print blank pages
I just bought a brand new Epson L210. But after filling the ink and install the driver, it prints only blank pages with no error message. Any advice?
Posted by Joni And on
  • 7 more comments
  • phoebeastudi
    phoebeastudi Feb 15, 2013
    Same problem? Its brand new! :(
  • Hannah Aug 07, 2013
    SAME PROBLEM :(
  • Jessie Balowing
    Jessie Balowing Dec 31, 2013
    same problem
  • Nasser Alhameli
    Nasser Alhameli Apr 30, 2014
    Same Problem! just now!
  • jannettebp
    jannettebp May 17, 2014
    same problem... how will I fix it. :(
  • victor Viktor
    victor Viktor May 17, 2014
    1.make sure,ink lock on the right is not in transporting position
  • victor Viktor
    2.refill ink 2 or 3 times and clean printer head
  • Borey
    Borey May 31, 2017
    I have refill ink already and clean printer head also, but it is still has the blank page.how to fix more?
  • Roy Ocubillo
    Roy Ocubillo Aug 14, 2020
    download adjustment program of epson L210. Then go to particular adjustment mode. select printer information check. & select "check" see if there is any Fatal Error. If there is jumper F1 in the logic board & I'm sure it will print.
Terry
  • Office Equip... Master
  • 11,377 Answers
Https://www.youtube.com/watch?v=mvgWn4pAKmM
https://www.youtube.com/watch?v=jKAxfHcDumY
Youtube videos showing ways to clean printhead in Epson L printers.
Posted on Apr 04, 2018
5 Related Answers
don_farr
Don Farrell
  • 1018 Answers
SOURCE: printing blank pages
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Dec 09, 2009
Testimonial: "thanks for the tips, it is manufacturer ink so i'll just give them a call thank you"
Anonymous
  • 1751 Answers
SOURCE: Epson CX8400 is printing blank
Hi
You need to replace the printhead
Pls vote us to keep us alive
Posted on Nov 21, 2010
Anonymous
SOURCE: epson c60 problem
Problems with Epson Stylus C43UX InkJet Printer Driver Downlaond
Posted on Jan 07, 2008
Basti
Edgar Allan Pagayona
  • 1447 Answers
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
Anonymous
SOURCE: CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
Posted on Oct 25, 2008
All blank pages when printing, new ink installed
You may not used the printer for a long time (1 week). The heads may be blocked. run the head cleaning utility.
Jan 08, 2010 | Epson Stylus C86 InkJet Printer
Epson STYLUS DX4400
Have you removed the pull off tape from the top of the cartridges, it lets air in enabling the ink to flow, easy mistake!
May 27, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Getting error message E-01 after getting blank print pages.
An ink cartridge is expended or not installed correctly. See page 36 in the user manual to resolve, available here:
Feb 28, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus C45 not printing
common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Feb 07, 2009 | Epson Stylus C46 InkJet Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
10,174 people viewed this question
Marvin
Marvin
