Fridge will not come down from 8 degrees
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
SOURCE: Fridge portion seems warm 60 degrees at lowest setting
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
SOURCE: my freezer stay at 8 degree, but fridge is saying
This can be caused by many things, there is a sensor that tells the PCB what the temp in the refrigerator, there is a sensor that tells it when to defrost, there is a thermal fuse, there are heaters in the refrigerator. there is a defrost damper that closes during the defrost cycle that can freeze or fail, I saw a guide on the online auction place, E b a y that may help. The first thing I would need to know is if there is ice build up on the condenser. If this is the case the the fan is being chocked off and can not blow cold air through the condenser. If your freezer is fine then the compressor is good since this is a dual condenser unit so no worries there. There is no damper between freezer or refrigerator. Look on e b a y for the manual i think it will help.
