SOURCE: Imaging Unit needs to be Replaced
No, what actually happens is the drum fills up with waste toner and you cannot empty it.
SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
SOURCE: My Samsung CLX-3175FN is asking
You will have to purchase an new imaging drum. It is the shiny green metallic cylinder in the bottom back of the printer. It is the last piece to come out when you remove the toner waste unit and then all the toners. It sits on the very bottom/back of the toner bay. They are not cheap but do not need to be replaced very often and it will give like new printing after.
SOURCE: How to replace the imaging unit for the Samsung
Hi. Here's a link for this printer. There is a guide inside the pdf file on how to replace the imaging unit. Please go to page 69.
Have a good one!
