Question about ZEEPAD VIA8650 Android 2.3 Tablet
My zeepad 7.0 wifi will not turn on
The wifi will not turn on.
Posted by Dee Kolanek on
  • Dee Kolanek Feb 11, 2013
    I have tried multiple times to reset the Zeepad to factory settings, but the problem with the wifi not turning on continues.  When I slide the wifi to on, it stays on for a few seconds then switches off on its own.  I continue to slide it to the on position and it wont stay there long enough to turn the wifi on.
  • SRDavis
    SRDavis Jan 01, 2014
    I know this is from a year ago, but I just got my kids the same tablet for xmas and my daughters is doing the same did you find a solution?
I have an iPad mini cellular. What should my settings be to use wifi when not in a wifi area
When you're on cellular, the wifi can be turned off, or left on. It's not a big battery drain and if you enter a wifi area, it'll switch to wifi saving your data plan. I've always just left mine on, but I turned off the prompts for new wifi networks.
May 05, 2017 | iPad mini Tablets & eReaders
Why does kids fire tablet keep turning off wifi?
Check the settings you must have turned auto turn off wifi to on state after some time
Jan 19, 2017 | Amazon Kindle
Wifi connection-kindle fire cannot find wifi signal - 3 ft away
The wifi connection may be turned off. I just had that experience on my Kindle. Once I turned it on, my next book downloaded.
Oct 07, 2016 | Amazon Kindle Fire HD 6 Tablet - 16GB
Can't access wifi.. after turning wifi on, no wifi network list appears
Press and hold the wifi option and then search for the network, else turn off both the devices and restart the router first, let all the lights come up and then turn on the tablet.
Jan 12, 2016 | Tablets & eReaders
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ‎23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ... Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
Dec 15, 2015 | Tablets & eReaders
Why is the WiFi in my rca tablet killing my battery to fast
Wifi always drains battery life to some extent or another.. Best solution is to turn off wifi when not in use or needed, and or keep your device plugged in during extensive use.. try to figure out your battery life while using wifi, and also kill/turn off any unnecessary background apps like gps, etc.. you can also extend your battery life by keeping your back light and lock screens to turn down and set to automatically turn off after a min or so of non use.. hope this helps..
May 04, 2014 | Tablets & eReaders
Meep will not connet to wifi
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
Jan 01, 2014 | Oregon Scientific MEEP Kids Tablet
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Zeepad 7.0 not connecting to wifi
the turn on wifi button when I turn it on it turns back off
Jan 24, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
ZEEPAD VIA8650 Android 2.3 Tablet Logo
246 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
