How old are the brakes? It sounds like you may have a warped rotor.
Sound like you have warped rotors. Replace the rotors and brake pads and you'll be fine.
This sounds like a Master Cylinder Problem. It will be ok for a while But, will eventually get worse if it is not Replaced. Please Rate My Response! Thanks!
The Speed Sensor has nothing too do with the Braking System............Are you sure that he did not Do something else while he was in there????
Yep! If he just Cleaned the Sensors and Reinstalled them and then Cleared the Codes, There is your Problem. Clearing the Codes will Reset Everything and will take a little while to register Back with and Bad Codes that are still Coming through the System. It seems like at this Point that one or Both of these Sensors are Bad.
Cool! I will be around! Good Luck!
Sounds Wierd too Me! I have Driven GM Vehicles all of my Life and I have NEVER Heard this Before. Maybe it was just a Temperature Problem since it is not doing it Today. I hope so! You could always get a Third Opinion on this from an Independent Mechanic.
Hmmm....ok. The mechanic I took it to a few weeks ago said it was wheel speed sensors. He "cleaned" them and the problem stopped...now it's back.
Nothing else. He took out both sensors (front), cleaned them and hub. Scan test. Also has C0201, function test ABS ok. Make sense?
Thanks! I'll let ya know what happens tomorrow; 8am appt. again!
I took in my truck this morning. They said my truck has "Power Boost", and "it's suppoesed to do that".
Really? It never did it before? Any ideas? The ABS doesn't "kick in"...it's just like someone is pushing against the brake pedal when I drive normally. When I push the brake softly I noticed that it wouldn't do it.
Of course, it's not doing it today. Temp is about 15 deg. warmer. Any more ideas?
doesn't do it all the time , step on brakes pedal wants to come back up
the back brake bulbs were changed how de the brake bulb inside the car by the brake pedal
