Refrigerators Logo
Question about LG Refrigerators
REPLACE lg LFX 25971 LED LIGHT
THE REPLACEMENT OF THE LED LIGHT BOARD PART # EAV43060808
Anonymous
I am having hard time taking the cover off. I am afraid it will break if I pinch it. is there a trick to it? what am I missing?
Posted on May 11, 2013
LG Tv backlights won't come on. Replaced bad LED strips and did not fix. Should I move to replace power supply/LED driver?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
LG 47LN5400-UA LED picture has gone out. Audio works. Using flashlight I can see faint menu image. LED Driver or LED Strips? How can I tell?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
LG 47LN5400 blank screen after brief flash
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
1helpful
How to fix LG 47LN5200 TV?
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
LG LED tv with sound but no picture
I have a LG LED tv, sound, no picture.
2answers
HOW DO I FIX MY LG 42LE5300 TV?
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Fix lg led tv with no picture but has sound
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
