Hello!, I have a Home Teather system Bose V30, the Bose have programed
a DTV and DVD Philips but, when i seek the commands for the Sharp to
program it in to the TV Source all the comands for the sharp don´t work.
I tried to attach a IR emiter for safety but doesn´t work.
Some body knows how's alternative manufacter work with this LCD TV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
SOURCE: Can't use on-screen programming
Hmm pink clouds huh? Sound like something is wrong? I think you might want to try to contact Home Solutions and either put in for a service call or look into getting the media center repaired. I would get it repaired if it plays DVD's fine
SOURCE: Apple TV and Bose Home Theater
I had the same problem.
I could not get HDMI to HDMI to work.
i fixed it (work around), by connecting ATV HDMI to DVD HDMI port on V30, i then connect L&R to AUX. I set the Bose remote for controlling ATV to AUX.
so to use ATV with Bose remote i know press DVD, this gives me the correct display but not audio, i then press AUX and this gives me ATV control and audio.
interesting, when i first set this up (trial and error), it didn't work. I was doing some cable management clean up, when i got a fright and the thing started working...but i have a ghost in my house so that is probably a more plausible reason why its working now.
it feels like this product is only 90% finished
SOURCE: Do you know the dvd code for samsung dvd-hd870?
send an email to bose support. i sent 1 email with 3 products (tv, bd-player, dishnetwork receiver) that I couldn't find in the setup screen. I got 1 email back and all are up and running - 48 hour turn around on email. had to use IR emitter on bd-player to get v30 to see it. I have samsung bd-p4600.
