Circuit board blew up
SOURCE: Subwoofer Module N-200 ( Nuance ) Short on circuit board
I'm working on a guys board looks like it is the Q10 and Q1 transistors I'll let you know how it goes.
SOURCE: Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
SOURCE: i blew the circuit board on my jbl pb12 subwoofer.
Sorry to hear that. The JBL PB12 are notorious for their amplifier module giving out. This item is not repairable nor is there a replacement (The module is potted into an aluminum heat sink). Actually, I need to clarify, as the late models used discrete components. If this is the case, either Repair it yourself (Google search PB12 Repairs) or take it to the local repair shop. (Or to a technical college with an electronics program, they may work on it!)
The best method is looking for a plate amp to replace the PB12 Amplifier - try the bash 300W. Several people have done this conversion. Be warned, you will need to do woodworking if you want to mount the plate amp on the box!
Testimonial: "thanks alot! not what i wanted to hear but helpful none the less!"
SOURCE: My Mirage S10 subwoofer
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
