Question about Lowrance Elite-5 DSI Color Combo Fishfinder/Chartplotter with GPS & Transom Mount Transducer 000-10236-001
When where is a DSI filter cable used
I am installing an elite 5 DSI fishfinder/chartplotter in my boat This is the only electronics i will have on my boat.My unit came with a DSI Filter cable Do i need to use this filter,or should i use this filter for my install
Posted by james grubbs on
robbie johnson
    Champion:
    New Friend:
  • 227 Answers
Use what came with the unit ????
Posted on Dec 25, 2013
1 Related Answer
odiebugs
odiebugs
  • 949 Answers
SOURCE: how do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Posted on Apr 13, 2013
Testimonial: "understand transducer hookup,need moore imfo on bettery hookup & fuse. thanks very muck"
It works fine for about 20 min.then it starts beeping and alarms ging off sometimes it stops for a few min and then it tarts again I can turn it off and back on and it does good for about 20 min is there a...
I THINK what you're running into here is a poor power connection. (either positive or ground) It would appear to me that as the connection heats up, it is unable to carry the amperage needed to keep the unit running.
Carefully inspect, clean and lubricate with silicone spray the connections, (pay particular attention to the terminals at the power supply AND the fuse holder.)
Hope this is helpful.
-Steve
Mar 30, 2015 | Lowrance Elite-5 DSI Color Combo...
My elite 7 won't read depth when boat gets on plane
The transducer MUST be in contact with the water for it to operate properly. Check and make sure (if it is a thru-hull) that the ducer isn't in the air when you're planing. I've read that wiping the transducer with Dawn dish detergent speeds up the "wetting" of the transducer and makes for a better contact with the water.
Hope this helps.
-Steve
Feb 26, 2015 | Lowrance Elite-7 HDI...
Where should I connect the NMEA data cables from my lowrance elite-5 chirp fishfinder combo unit.
you only use if you connect a radio with long/ lat display or auto pilot. otherwise do not connect them
Sep 22, 2014 | Boating
Why didn't my Navionics gold card download work?
Your running an elite 7. It's not compatible with navionics platinum.
Sep 04, 2014 | Lowrance Elite-7 HDI...
Navionics card wont work
You most likely need to change the map data displayed.
The elite series won't change for you automatically. Lowrance Elite 7 HDI Hybrid Dual Imaging Fishfinder Chartplotter
here is a link to the elite 7 page where you can download a pdf owners manual.
go to the gps/map page on your unit. Find "chart data" on your menu.
select nation is as your chart data. Then you will be ableaving to see your map data.
Jul 30, 2014 | Lowrance Elite7m Chartplotter With Gold...
How do i install elite 5 dsi on 14' tiller boat
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
Sep 21, 2012 | Lowrance Elite-5 DSI Color Combo...
How can I connect my chartplotter to my flatscreen tv
absolutely not! sorry that is the answer, no video out available period
Dec 19, 2008 | Furuno 1650wf/Nt...
Lowrance Elite-5 DSI Color Combo Fishfinder/Chartplotter with GPS & Transom Mount Transducer 000-10236-001 Logo
1,285 people viewed this question
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
