If the select button functions correctly, then it sounds like you have a wire broken or a wire nut that holds a bundle of wires together has fallen off. If it was the solenoid link, then the Select function would not work. After removing the bottom cover, look for the orange wires, That is the cycle circuit. Look for a broken or unattached orange wire from the side button and the remote receptacle.
The other possibility is that the direction lever is stuck, bound up or the direction lever spring is broken. The attached image of the top plate of the slide change mechanism will show you the end of the direction lever. It should move freely, up & down on its center pivot. You should see a small, wire spring, about 2-3 inches long on the lever. If the spring is not there, or the lever does not move freely, that may be the cause of no forward or reverse.
SOURCE: Kodak Carousel 600 Projector - mechanism stops with slide out
Open the back up and spray just a LITTLE bit of WD-40 into the cavity where the bit of spring emerges from the grease covered cam shaft. This will loosen up the grease that has dried up. It may take up to half an hour to work on the grease. If things are improved but not perfect, repeat. If any WD-40 spills out, mop it up with Q-tips and especially avoid the rubber belt.
Please do NOT advance things manually ans especially don't pry apart any of the plastic or metal cams on the cam shaft in an effort to correct the timing. You will put it out of waht and it will take a whack of time and/or an expert to get it back in whack!
SOURCE: My Kodak Carousel 760H projector will not advance
The problem is a plastic "link" that connects a solenoid to the advance mechanism. It gets brittle with age & cracks, yeilding the problem you have. You need to have the "link" replaced.
SOURCE: Kodak Projector 760H. Carousel won't
Chances are that your projector has a broken solenoid "link". This "Link" connects the slide change solenoid and the slide change mechanism. Over time this part becomes brittle & cracks, rendering the slide change non-functional. A pretty easy fix for an authorized repair dealer.
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
SOURCE: Kodak Carousel 760H wont advance or reverse
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
