Question about Archos 504 500870 Digital Media Player
Archos 504 code 3
Recovery code 3 no repair format no matter which one i pick it just keeps going back to this screen and this solution is not working [ I had the same problem and manage to solve it. You need to do the following a. go to Archos website and download latest firmware and save on your pc b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!) c. connect 504 to pc and wait until pc recognise it (it will recognize it this time) d. copy firmware from pc and paste it to 504 root directory. e. press done on 504. now when the device restarts you just select Repair and that should work. :) By zalmayNov 08, 2008 ] gold button on inside doesnt work either please help
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Archos 504 huge problem
I had the same problem. I droped mine and it seems to have messed up my hard drive. i replaced it today and my comp. can now reconize it. i have been trying to contact tech. support to see if it is possible to get the OS back on the PMP. if the Tech support ever picks up my call i will message back with the fix.
Posted on Aug 08, 2008
Anonymous
SOURCE: recovery code 104 for the archos 405 mp4 player
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
Posted on Feb 01, 2009
Anonymous
SOURCE: recovery code 103
click on repair, then when you get the done notice just plug in to pc and it be recognised
Posted on May 17, 2009
Anonymous
  • 5 Answers
SOURCE: Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
acharlesc
SOURCE: My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Posted on Aug 17, 2009
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
Getting a white screen with 102 error message
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
My archos 5 wont switch on to the home page
You should perform this when it is on
problem solve #1
* Press the reset button on the buttom of the device using a papr clip. It should shut it off. then try to turn it on again.
try the next if the problem still exist.
Problem solve 2
* Download the latest frimware from Archos.com on to the desktop on your computer ( i recommend desktop because it will be easy to find) Then plug the device to a pc Using USB cable. turn the archos on by holding power switch and TV/LCD buttons at the same time until a white screen comes up. it should ask for Usb. if it does pick the ubs. if it does not give you a USB option but these "NO", "REPAIRE", "FORMAT" move the curser to repaire. do not pick the format which will delete all the contents and plugins you have on your device.
after repaire completes it should say done. do not press the done wait until you see the archos connection under My computer. it should normaly come up with name 504 or you will be able to see the archos icon. place the firmware in to the main drirector not under any folder. then press the ok button to confirm the "done" device will power off and start with a white screen again but this time it will update the firmware and restart do not unplug the Usb cable until the update completes. It should restart again and load the normal user interface. Your device should be fine and back to normal.
Jan 03, 2009 | Archos 504 500870 Digital Media Player
Recovery code 104 for the archos 405 mp4 player
Dec 27, 2008 | Archos 405 Digital Media Player
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
Can't get out of recovery code 2 on archos 504
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Recovery (code 2)
open the battery pack, and push the hard drive back into it's slot.
it has prongs that attach, tat was always my problem.
sorry if it no help to some.
Sep 29, 2007 | Archos 504 500870 Digital Media Player
Help me pleaseeee
sent it back to archos with your receipt if less than 1 year and talk to customer service
there is nothingg you can do about it
been there done that.
Aug 28, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
51 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
