I have a harman/kardon subwoofer. Model 395. Is there anyway to make it work with out the satellite speakers.
Posted by Randal Tootle on
John S
Here it is for everyone, just jumper it like this. Yes, those are staples. Works great.I have a harman/kardon subwoofer. Model 395. Is - ee01bf86-560a-45fe-a27b-81d722aeefd2.jpg
Posted on Mar 16, 2020
  • AndyFort
    AndyFort Dec 27, 2020
    thank you very much!!!!
  • Brandon Garrett
    Brandon Garrett Jan 21, 2023
    I can't clearly see what goes where?
2 Related Answers
Anonymous
SOURCE: Harman kardon HK595
I'm not sure of anywhere online, but I actually have a spare set of the satellite speakers sitting at my house, from a unit I had previously (the sub went out). I can make sure they work and get them to you if you'd like, email me at drkstr (at) gmail (dot) com...
But I have only one spare...
I'm not sure about wherever else you can buy them online. I was actually lookin to buy another set when I stumbled on this thread, but they're kinda hard to find lol. The whole unit used to be $30 for a refurb'd model, but those places are out-of-stock currently.
Posted on Jan 05, 2009
Petrica Voicu
  • 64 Answers
SOURCE: where can i buy the cable to connect the
Posted on Aug 07, 2012
Explain connections - harmon kardon 130 to 4 jbl satellite speakers one middle speaker and seperate jbl subwoofer 140/230
Hello Ranasinghe, you must connect a JBL satellite for each Main L and R output (2 speakers in total)
Connect one JBL for each Surround L and R output (2 speakers in total)
The middle speaker, to the output of the Central channel and the subwoofer, if active or powered, to the RCA subwoofer output on the amplifier
This way you would have all the speakers connected in the Harman Kardon 130
Hola Ranasinghe, debes conectar un JBL sat?lite por cada salida Main L y R ( 2 parlantes en total)
Conectar un JBL por cada salida Surround L y R ( 2 parlantes en total)
El parlante medio, a la salida del canal Central y el subwoofer, si es activo o potenciado, a la salida RCA de subwoofer en el amplificador
De esta manera tendr?as conectados todos los parlantes en el Harman Kardon 130
Why doesn't subwoofer work?
Your nose and eyes should lead you to the faulty part for this, once you get inside the subwoofer. Anything that burns up producing the smell will possibly leave a visual trace. But your nose will lead to the part that smells. Replace it and see what happens!
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Do i need a satellite cord for this harman kardon to work properly
You shouldnt need a satellite cord. If the HK 12 has parallel L and R inputs and outputs, you should be able to run sound into the sub, and then out to whatever speakers you have. Assuming they are not a part of a sound system, and you are running 2.1 stereo.
24helpful
2answers
Del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
2helpful
Harman kardon HK595
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
 Grubhead
Grubhead
Marvin
Marvin
