Question about KitchenAid KEMC377K Convection / Microwave Oven
Replacing door switch on kitchenaide superba microwave convection oven combo
I keep getting "DOOR" message on display. I've changed the 20 amp fuse, but cannot locate the 15amp fuse. Need to see how to get into the microwave to try and test the switches.
Posted by Joel Willis on
  • Joel Willis Feb 10, 2013
    Still can't figure out how to get to the switches. I see them and can unscrew the from the outside but cant get in the microwave itself to get them out or replace them.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
Anonymous
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: my kitchenaid microwave/convection oven shows "DOOR" on display
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Sep 20, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Posted on Dec 22, 2009
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: We have a KitchenAid Superba microwave and oven
Hi, it is caused by a blown 20 amp fuse in series with the Primary door switch.
CORRECTION: Most often the first attempt is to change, or adjust, the primary door switch, but components (20 amp fuse, 15 amp fuse and cavity thermostat) in series with the primary door switch are the culprit. Check and replace as necessary the 20 amp fuse, the 15 amp fuse or the cavity thermostat.
Posted on Apr 25, 2011
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
Microwave stopped working
Hello there and welcome to fixya
This is a fairly common issue with microwaves
Normally the issue that you are dealing with is that the dor switch has went bad or the electrical wiring may be getting loose so what i would do is first remove the outer shell of the microwavethen get to the door switch and find the wires that are going from it to the connection poing then make a note of where the wires are connected at then remove the wires and test using ohm meter set at the lowest setting you should be getting a ol reading when the door is open then shut the door and you should show a little bit of continuity when the door is shut something like 020 or something like that however if it does not move or the numbers are really high then it should be replaced ok
I have posted a link here for you to follow on how to test it and several other parts ok http://www.ApplianceRepairLesson.com
Feb 10, 2012 | KitchenAid Microwave Ovens
Dec 22, 2009 | KitchenAid Microwave Ovens
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
How do you replace the lamp in a Kitchenaid Superba microwave convection oven combo? What type of lamp?
open the top cover then you can see the bulb on the right side of the oven, just remove the lamp and replace it by a similar one. you can try to get the lamp from any electrical shop with the same size and same rating.
Jul 14, 2009 | Microwave Ovens
Mar 26, 2009 | KitchenAid Microwave Ovens
KitchenAid KEMC377K Convection / Microwave Oven Logo
1,192 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
