My phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Go to you tube enter your question and when new page appears go to Air Communications Video and follow on screen instructions . Hope this sorts your problem.
Lialiuz
SOURCE: My blackberry curve 8520 loading
my blackberry curve a red light comes on then it only loads half way then crashes what will a do
SOURCE: Only getting about 10 hours standby on Blackberry 8520
Hi one reason batterys dont last as long as they should is that when you charge them up they never achieve full charge and some cells will only take between 50 and 65 % charge, what you should now try is letting the battery go totally flat so that your phone wont even light up when you try switching it on keep doing this until the battery is totally dead, then give it a full recharge, you should now find it lasts a lot longer, you should aim to do this once a month to ensure you battery stays at its best, they dont tell you this when you buy the phone but it is common knowledge in the phone industry.
give it a try and you should be surprised what you find.
How ever you cant always believe what the phone adverts tell you because their are heavy duty batteries you can buy for certain phones, but if you think you have a good case of false advertisement then contact the phones makers and have a word with them they may even send you some free extras as they like to keep their customers happy,
You also got to remember that standby time means 17 days if the phone is not used and no one rings it say you take the sim card out then give it full charge, then with the sim card out see how long the battery lasts then this will give you some idea of the things that use the battery up such as alarms, people ringing, texts, even when you press a button this uses power to light the screen up so you can only rely on standby time if the phone is sitting their doing nothing.
i hope this as been some help to you
SOURCE: BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
SOURCE: is mixit posible on a blackberry 8520
Hey a can download my mxit but when a whant to open it says erre 11 I am celc pleas help
SOURCE: Blackberry 9700 just shut down and would not
Since it's not possible to do a "wipe", what you could try to do is to soft reset the phone.
Remove the battery while the phone is turning ON, leave the battery out for five minutes, put it back and try to turn it on.
If the same problem occur, contact the manufacturer because the problem has something to do with the software, application, or firmware. The phone needs to be reprogrammed.
Thank you and good luck!
