SOURCE: Need VIA AC'97 Enhanced Audio Controller Driver
You probably need the M/soft UAA drivers first download and install them
Then go to device drivers right click driver with yellow mark on it and upgrade driver should go on net and find and install driver
SOURCE: I would like to sapier vhich processor's are
Well there are probably hundreds of CPU's compatible with your motherboard. What you need to know is the kind of socket it has.
The most common are AM2(dualcore) and AM2+(quadcore) sockets.
You can just try some sites that let you build your own pc. if you then submit your motherboard there, in the next step you will get a list of ONLY cpu's that are compatible. But if you find one, you should still check.
You can find hundreds of sites just by googling "build costum pc" or something like that.
I hope this helps,
Yannick
SOURCE: Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Testimonial: "Clear data to upgrade my PC. Thanks"
You can Download Here it having all drivers reg this mother boardhttp://twotechkys.blogspot.in/2017/09/do...
