Hi, I've used this company/website for over 12 months now with no issues whatsoever: Sharp LC 29LE440M
However I would expect that Sharp would offer this firmware upgrade direct if you are still unsure
Top brand microwaves cost anywhere from $50 to $650,depending on the features and the quality of the microwave. For a complete listof microwaves and their prices, check out this website: http://www.abt.com/category/14/Countertop-Microwaves.html
pls dismental remote , just pull it corner of the front and rear side with shrap edge of knife the clean with contact cleaner or petrol and vaparize chen assenble again and try with using new battries
Sharp AR-122
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
Image Processing Unit error
01
Memory back-up battery dead
02
Laser unit problem
03
HDD defective
10
black level calibration error
11
white level calibration error
13
CCD calibration error
90
F1
00
Lost communication with the Sorter
01
Sorter registration problem
02
Paper transport motor overloaded in sorter
04
Bin position error in sorter
05
06
Shift sort motor overloaded
08
Stapler position error
08
Stapler overloaded
11
Sorter problems
14
Second shift tray jammed
15
Sorter drive problems
50
Sorter not installed properly
80
No powerin sorter
F2
00
ID pattern reading error
02
Toner add mechanism malfunction
31
32
39
Drum thermistor error
F3
12
Paper does not lift in the tray
22
F9
00
Printer board problems
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
Fusing unit temperature error
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
Papersensordefective in the fusing unit
02
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
02
U2
00
EPROM error
11
EPROM error
U4
02
Duplex not working properly
03
Duplex problems
U5
00
Communication with the ADF is lost
01
Registration sensor problem in ADF
02
Exit sensor error in ADF
03
Timing sensor problems in ADF
11
Paper feed drive overloaded in ADF
U6
01
Paper lift problem in 1'st optional tray
02
Paper lift problem in 2'nd optional tray
08
Paper feed unit without power
10
PFU paper transport motor overloaded
22
50
Paper feed unit not installed properly
51
LCT not installed properly
U7
00
Main board malfunction
U9
00
Op panel problem
90
Op panel problem
EE
EU
Low toner density in the developer
EE
EL
High toner density in the developer
FA
01
PC
Key counter not installed
Sharp AR-650
Код ошибки
Подкод
Описание
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
01
02
Laser unit problem
03
HDD defective
10
11
13
90
F1
00
01
02
04
05
06
08
08
Stapler overloaded
11
Sorter problems
14
15
50
80
No powerin sorter
F2
00
02
31
32
39
F3
12
22
F9
00
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
01
H4
00
01
H5
01
02
L1
00
L3
00
L4
01
L6
10
L8
01
02
U2
00
EPROM error
11
EPROM error
U4
02
03
Duplex problems
U5
00
01
02
03
11
U6
01
02
08
10
22
50
51
U7
00
U9
00
Op panel problem
90
Op panel problem
EE
EU
EE
EL
FA
01
PC
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i
Код ошибки
Субкод
Описание
E000
0000
Fixing temperature abnormal rise
E001
0000
Fixing unit temperature rise detection (by main thermistor)
0001
Fixing unit temperature rise detection (by sub thermistor)
E002
0000
Fixing unit temperature insufficient rise
E003
0000
Low fixing temperature detection after standby (by main thermistor)
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
Fixing film rotation error
E010
0000
Main motor rotation error
E019
0001
Waste toner full detection
0002
Waster toner full detection sensor failure
E052
0000
Duplex unit connection error
E100
0000
BD cycle out of range
E197
0000
Erroneous communication with printer engine
E500
0001
Finisher communication error
E520
0000
Offset error
E531
0000
Stapling error
E540
0001
Paper surface not detected (standard tray)
0002
Not moved within the specified time (standard tray)
0003
Sensor not reached within 3 seconds (standard tray)
0005
Encoder clock failure (standard tray)
E542
0001
Paper surface not detected (optional tray)
0002
Not moved within the specified time (optional tray)
0003
Sensor not reached within 3 seconds (optional tray)
0005
Encoder clock failure (optional tray)
E575
0000
Stack delivery error
E584
0000
Shutter failure
E716
0000
Erroneous communication with optional cassette
E719
0000
Erroneous communication with card reader (serial communication)
0002
Erroneous communication with coin vender (serial communication)
E733
0000
Erroneous communication between controller and printer
E736
0000
CCU communication error
E739
0000
Erroneous communication between controller and network board
E744
0001
Language file/boot ROM/USB memory error
0002
0003
0004
E805
0000
Fan failure
E808
0000
Fixing drive circuit failure
