Hey Bindi, still need the answer?
It depends on the outputs from your TV.
Hopefully you have two round ones like the red and white pair on the back of the Audiosonic KW3508 soundbar.
These are called RCA plugs. You may have multiple sets, but you want the output ones!
Should be able to find an RCA cable cheap at ur local 2nd shop for less than a buck.
If you only have a headphone socket, you can find a 3.5mm Male to 3.5mm male cable audio cable at ur local electrical shop, but any nerdy friends might have one lying around. This plugs into the side of ur soundbar.
gl,
Andy!
How do I wire up a KW-3508 soundbar to a aamplifier running a surround system thru a Samsung 3D Plasma tv,I already have front and rear sp[eakers with a sub woofer and was trying to connect it to existing centre speaker connect but couldnt get any sound.Any thoughts
short answer is you wouldn't!
Most soundbars, including yours, are designed to take UNamplified sound, commonly called line level. Running amplified wires from ur amp to it will likely blow some of its circuits!
It also isn't appropriate, meh, just get a cheap centre speaker at ur local second hand store similar to ur existing speakers - check the details on their back for Power (W) and Ohms ratings.
