Computers & Internet Logo
Anonymous Posted on Feb 07, 2013
This happens when I start the computer. It seems like that I attach a disk, but I do nothing!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
37
Points
Have you recovered your computer recently? Because the PQService partition is a partition that allows you to restore your drive to factory defaults.
You might be able to right-click on "Computer," select "Manage," go to "Disk Management" and right-click on the drive ( should be labeled J: ) and select "Change Drive Letter and Paths" and click the "Remove" button.
I'm not sure what any of these commands are in German, but this picture should explain it.
This happens when I start the computer. It seems l - 2_7_2013_6_22_01_pm.png
Hopefully that will work.
  • Anonymous Feb 07, 2013
    Thank you for the answer. No I didn't recover my pc recentely. I have find the problem, it sound strange but in the background was TomTom Home running. I removed that, and the problem solved. I think the software waa corrupt. I sm sorry for my bad English, I am Dutch..
    Thanks Again
  • Anonymous Feb 08, 2013
    Oops, sorry about that, the video is pretty small on my phone. I'm glad that you were able to solve it, and that you came back and posted the answer. Someone in the future will probably benefit from your answer.
With only 3% of memory remaining my husband decided to perform a disk check but was doing something on the computer so clicked schedule for next start up (or something) so when I next turned the computer...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a FLAT RIBBON 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
if you need more help with this post a reply
hope this helps
Hi, my MSI GX700 does not start. When I press the start button, witness DEL switches on between 3 and 7 seconds, and is turned off. The hard disk does not start, the screen does not switch on. There...
Cheers!!! Case1. Either RAM or Hard disk not working fine. Disconnect and reconnect them if then port connections are loose. Otherwise, need to replace broken RAM or Hard disk. Case2. Bios Chip is gone. Visit the computer repair shop.
ASUS Eee PC 1005 HAB it won go after the "press f2 to run setup, press tab to display BIOS POST message" screen. When i turn it on it makes a sound inside the computer for like two seconds after...
It seems something wrong with the Hard disk, remove the Hard disk and memory card and reset them, then start your computer,,,If doesn't work, try more times, remove graphics together is better
Computer wont start up it says "push F2 for setup" i do it goes to another page and says "please waut" but nothings happening?
It seems to me that the boot files are corrupted. It is suggested that you perform recovery if you have recovery disk or reinstall windows.
1helpful
When i press the power button the fan starts up but nothing else happen. sometimes it turns on and when it does, i can use it normally for days.
seems like you have hard disk issue.
I would suggest that the next time you computer power up fully you backu up everything that is important to you.
you will need to take your computer to service so they will check your hard disk.
Hi Ihave a Sony Vaio VGC-LN1M won't boot up??
Check the sata cable attached to your hard disk, check your memory maybe its already damaged and check your power supply if it supplyenough power.
Cd drive viewing in computer does not work
well it seems that your system is not able to detect the cd in the system so you must get the lense cleaner to clean the lense of the computer.
Computer freezes after start up!
It seems to be a virus attack. Place the boot disc on the CD-ROMand reinstall the OS by repairing option. If there is nothing of importance on the hard disk I would advise total format and do a clean install. This should solve all problems,,,,sodeep(remember to keep the MB CD handy tp load all the drivers after installing the OS)
Cant download attachments in windows mail
Do a disk clean up to free some spces on your hard drive. Also, remove all the temporary files on your computer. You can do this when you ran disk clean up
Start -> type disk clean up
Bala
Grand Canyon Tech
Grand Canyon Tech
