Black screen. fan runs for 3 sec then shuts off. tab led light blinks and it will not shut down after pushing the power button not even after i hold it down
could be over heating,can you hear the fan running?if not get a hoover and put it to the side were the fan is and clean it out that way,if that does not work you may need to open it up and clean it.
The mounting to the motherboard is with a BGA surface mount. Ball Grid Array.
The bottom of the graphics chipset has Solder Balls. The mating area on the motherboard has matching Copper Pads, and they are gold plated.
The graphics chipset is set into place with the Solder Balls, lining up on the matching Copper Pads; and heat is applied at a specific temperature, and length of time.
This action melts the Solder Balls, and solders the graphics chipset TO the motherboard.
Due to the constant overheating the solder connections (joints) made, are partially melted. Then when the laptop is turned off the graphics chipset cools down, and the solder joints re-solidify.
This causes Cold Solder Joints, and a poor contact of graphics chipset to motherboard.
The solution is to add more surface area, to the small metal plate of the Cooling Tube, that sits on the graphics chipset. Plus reflow the solder joints for the graphics chipset.
BEST, and surety of repair; of reflowing the graphics chipset's solder joints; is to use a BGA Rework Station.
Watch a BGA Rework Station at work, and also view more information about the BGA surface mount,
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
those are POST code, error codes, you need to watch time and count them. report them.
leave the battery main out.
does it run ok now? yes/no.? main battery out?.
even new cheap batteries fail easy and hard and short out.
test it with no main battery. it can run on AC power for ever.
are you going to run the COIN cell RTC battery for 10 more years.
it wont make it..
this PC is 10 years old today (can be) so is RTC battery end of life. most fail in 5 to 7 years, says the pink bunny. (and is correct)
the manual shows how to replace it at the real HP Site,
fixya is not hp, not at all.
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure (RTC coin cell dead)
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times (or RTC dead)
System board
General system board failure
LEDs blink 6 times (or RTC battery dead)
BIOS
BIOS authentication failure
When does it shut down? Does it boot up and allow you to do anything? If it allows you to do some things then maybe it is running hot and shuts down or a virus is shutting it down. Give us more details on when it shuts down and what was going on when it shut down.
Classic symptom of the nvidia graphics chip failing. Why it failed to shut down I'm not sure of. What has happened I think, is that the laptop, while running, has built up enough heat to fry the graphics chip ( of caused the solder to loosen). The cpu will withstand the heat, especially as it gets cooling directly.
You can try and strip it to clean out the fan and heatsink of debris and dust, however, in this case I suspect the damage has been done and you will need to get the chip "reballed". Costs about 60.00 on Ebay.
