SOURCE: We are now getting a
U1 means the unit has failed to prime with water within 3-4 minutes.
Its taking longer than expected to fill with water.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
SOURCE: Dishwasher beeps 3 times and won't start
I finally solved this problem by doing the following:
I removed the front plate, this can be done by removing the two round plugs one on each side of the lower front of the washer just above the rack. once you do this the front comes off, then you remove the ground wire.
From the front upper right there is a photo sensor in two plastic tube, make sure they are in correctly and not slipped out of position.
My washer, it appears the plastic casing that is holding the circuit board and the sensor broke off on one end, I simply taped it to the main body by using electrical tape and made sure it was secure.
I put everything back and now my washer doesn't stop anymore.
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
SOURCE: hi ya. we have a fisher and paykel nautilus
This means something wrong with the water heater.
Most likely you will need to replace it. It will look something list this.
Will need a technician to fix it if you are not very comfortable to handle such equipment.
Please rate this solution.
SOURCE: fisher/ paykel dishwasher says F3
F3
means your dishwasher water is too hot. Go to the link below and it
will show you how to determine what is causing the error.
http://www.appliancerepairlesson.com/category/dishwasher-common-issues-repair/
Good luck
