Question about Thermador Ovens
Thermador c272ub double oven is it single fase wireing
On the wireing it has 4 wires red/ black/ green n white joined together
Posted by jeff eldin on
daniel hendrickson
    President:
  • Thermador Master
  • 1,922 Answers
Yes,the black and red era the 2 wires that supply 120 volts each for the required 240 volts necessary to operate the oven,the white is the neutral wire and the green is the case ground wire,and it should be connected to any metallic part on the oven not with the white wire,only if the power supplying this oven comes directly from the main power panel in the house and isn't off a sub panel before the oven can this be considered ok to be connected together
Posted on Feb 07, 2013
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
Anonymous
  • 700 Answers
SOURCE: ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Posted on Dec 26, 2008
jumptrout51
steve
  • 3361 Answers
SOURCE: Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
Posted on May 24, 2009
Anonymous
  • 235 Answers
SOURCE: I have a Kenmore 9114012190 Oven. 3
Red and black are hot and white is your neutral. Should have a green one too.
Posted on Jul 05, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Posted on Aug 02, 2009
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
The timer has a brown and black going. that's ok. but coming out is a red, an orange, a brown and a white. not sure which to join up.
Join the orange to the red wire, and then join the brown to the white wire. I have done that and everything is working perfectly (except of course the pre-programming which the clock would do).
Dec 04, 2014 | Stoves 720EF Electric Double Oven
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
4 conductor wiring for a range, red goes to red, black to black, does the white and yellow go to the middle together?
white is the neutral line and goes to the "N" terminal, the other is YELLOW??? not GREEN,which would be the safety ground to the units case you can use the yellow as a safety ground wire and terminate on the case metallic structure, but by N.E.C. only green colored wire can be used as ground wire or any wire marked with green at any place visible or connection point
Sep 24, 2009 | Ovens
How do i wire a newworld es50s in. I`ve been having problems i`ve conected all wires and only had 2 of the hobs working
if its 240volt and you have a 3 wire receptacle, (crows foot) and the new stove has 4 wires:i.e. a RED-BLACK-WHITE-GREEN on the oven unit, your red/black are your 2 hot wires white goes to neutral, and Green is safety ground put the WHITE and GREEN together, as long as the receptacle comes DIRECTLY from the Main Panel in the House, they use a 4 wire systen in some locations depending on local codes/any new installs require a 4 wire plug install now per the N.E.C.
Aug 23, 2009 | Ovens
I have a Kenmore 9114012190 Oven. 3 wires,red,black,white where does the white wire go?
there should be a wiring diagram on back of access door or somewhere on unit!!!
Jul 05, 2009 | Kenmore 40192 / 40199 Electric Single Oven
Blodgett convection oven how to wire it
They can tell you right on. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
May 03, 2009 | Blodgett CTB BASE Electric Single Oven
Smeg Oven digital clocks
two wires drive the clock itself so trace which these are by looking at the track on the card. join the other two. there may be linking across as well.is it a single oven?
Jul 18, 2008 | Smeg SE399X/5 Stainless Steel Electric...
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Ovens Logo
Top Thermador Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Charles Tidwell
Are you a Thermador Oven Expert? Answer questions, earn points and help others
