Question about Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
Same basic problem as described by hudson2212 on Aug 26, 2008 in the thread "Where to buy parts for Danby duel zone..."
Also, same general thing as posted by dudley on May 30, 2007 in the thread "Dose not get cold enough?" and by several others.
Basically, the unit sounds like it is running, the compressor runs and gets hot, but I hear no fans running to blow air over the coils and cool the unit. The unit reads as 63/64 and refuses to cool below 60 in either the top or bottom.
From reading through the other postings seems like everyone is having the same basic issue but nobody has a solution. I called my local service shop and they don't handle Danby... Please, if you know the real solution post on this thread so that everyone who gets hit with this common problem will know how to deal with it.
Is it the coolant? Condenser? Circuit Board? Relay?
Thanks!
Posted by grant433 on
  • 1 more comment
  • Anonymous Feb 26, 2009
    I HAVE THE EXACT SAME PROBLEM. MY COMPRESSOR RUNS AND GETS HOT BUT DOES NOT COOL UNIT.WHAT'S WRONG.
  • Doug32 Mar 28, 2009
    I have the same problemand the top fan dosent work. I switched the fan plugs and the fan itself works, so its a control problem...anyone help please.
  • TheDuck20 Mar 31, 2009
    The unit no longer cools and compressor is very hot. I noticed that the fan in the lower section is running, but the fan in the upper section is not. I reached around back and touched the compressor and you could have fried an egg on it! I got in contact with a couple appliance repair companies and they will come to your home, diagnose, and fix the problem. Be careful though. I was told by two different companies of a "diagnostic charge". Apparently, this is where these companies make their money. Kinda like "shipping and handling". Ridiculous. Not all are like this though, so be sure and ask. If you e-mail the service department at Danby, they are very good at finding these repair companies in your area. Haven't had the time for them to come out yet....Hope it's not a HUGE problem. Anyone have a similar situation and how much were the repairs?
magna buff
  • Danby Master
  • 3,828 Answers
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Compressor runs and gets hot but does not cool uni - 55379939-1b0e-474e-86bd-e34da24e7d79.jpg
Posted on Mar 06, 2017
1 Related Answer
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my danby beverage centre does not cool anymore 3
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Posted on Oct 08, 2010
Where can i buy accessories for danby premier DPAC12010H
Fixya is unable to suggest sources for Danby parts other than perhaps Danby.
Jul 09, 2018 | Danby Heating & Cooling
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
How much is the cost for a new Household Microwave Oven (Danby)
To replace your model of Danby.... costs around $90 bucks. To fix ur Danby if its broken.... $65/hr service charge (minimum) plus parts.... We are in the disposable society, sad... but its cheaper to throw ur microwave away unless u know the basics to fix it ... like a fuse replacement. Otherwise,.. just go out and buy a new one.
Apr 03, 2009 | Microwave Ovens
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
E2 = Not draining
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Danby DWC283BLS Wine Cooler Logo
2,841 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
