Yes it should. I would remove all of the contents on card and save them then reformat the card and check to see if the full space is available. If not there is freeware available to restore these things to correct amount. If it cannot be done then the card has an issue and needs to be replaced.
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
The problem may be that you used a data disc mode. That leads to discs that can be read by other computers not by most DVD players. Did you finalize the disc before removing it from the computer? Try finalizing the disc. From Windows File Explorer, select the DVD drive and choose the Manage tab. Then see if Finish Burning is available.
#1 Insert your ( memory card , flash disk , cellphone , .... ) into your computer. #2 Open up 'My Computer'. You should see it under the list of available drives. #3 Check its contents first to make sure that you have the right drive. #4 In 'My Computer', right-click on the drive and choose 'Format'. #5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. #6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
you may need to format the memory card using your player so it recognises it, i may be more of help if you can tell me what player you are using, im guessing mp3?
