Question about Wine & Spirits
What is a coffee percolator? - Wine & Spirits
Posted by joel marks on
roger nori
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
A percolator is a type of pot used to brew coffee. They are not used very much nowadays, since the introduction of other methods such as the drip, French press and espresso machines.
Posted on Feb 07, 2013
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
Maui outlets for Farberware percolator do not carry filters? Why?
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine.
enjoy your coffee
kolbrun
Jul 03, 2012 | Farberware FCP280 Stainless Steel...
Why won't our poly perk percolator shut off?
I just bought a Poly Perk percolator from a thrift store. If yours is the same, it's a vintage plastic, electric percolator. I found your question while searching for directions for mine. My percolator does'nt shut off either. It just continues running. I don't know if it has a shut off, but I figure I'll just unplug mine for now since it made really good coffee. If it's supposed to shut off, I suspect we're both stuck with few options. I hope you find your solution though.
Jan 18, 2012 | Regal Coffee Makers & Espresso Machines
Will not turn on
Hi, What brand coffee maker? bobbyone
Aug 27, 2009 | Coffee Makers & Espresso Machines
I need a user instructions for my dualit coffee percolator
http://www.dualit.com/news/docs/Percolator%20Manual%20GB.pdf
Is this your percolator? This one was the only one I could find, I hope it helps.
Aug 25, 2009 | Coffee Makers & Espresso Machines
Regal Ware coffee maker 58001R not brewing
I'm afraid the heating element is burned out.
Feb 24, 2009 | Regal Ware 58001R
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Wine & Spirits Logo
179 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
