Re: Tv will turn on and after 10 seconds will turn off,...
Have you did a lamp reset after lamp replacement? If not, this might happen. If you wish to know more about the lamp reset procedure to projection TVs, check this site.
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Hi, If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem. Lamp is not dead or broke but weak so you get above said problem in tv. Thanks.
Hi, Turn On tv. Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen. Hope this info will help you. Thanks.
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
