The First Years All Purpose Steam Sterilizer Logo
A
Anonymous Posted on Feb 07, 2013
Instruction manual for The First Years - All-Purpose Electric Steam Sterilizer
Jennifer Desouza
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Feb 08, 2016
Jennifer Desouza
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
2120
Points
7
The instructional manual is present with the pack of Electric Steam Sterilizer. I would recommend to have a PIGEON ELECTRIC STEAM STERILIZER checking the price from Fortis Healthcare
Little Sister 3 Autoclave is displaying FILL but does not actually fill and goes no further. What can I do?
Technical Manual and other suggestions. Professional machines really need professional service as the repair is very specialized, and the dangers of using incorrectly sterilized tools injurious to health.
T echnical Manual
Frank's Hospital Workshop http://www.frankshospitalworkshop.com > Esch...
The SES Little Sister 3 is a portable electrically operated steam autoclave suitable for the sterilization of unwrapped metal instruments and utensils. 4. The ...
47 pages
Watch out for These 7 Common Autoclave Problems
Consolidated Sterilizer Systems https://consteril.com > common-autoclave-problems
1. The sterilizer won't reach the temperature set-point. · The steam generator is need of repair. · There is a clog in the chamber drain (i.e. check the chamber ...
Missing: Sister ‎' Show results with: Sister
The Pelton & Crane autoclave in my office keeps giving me a P-2 code and will stop running. Anybody know what this could mean?
Question re-worded for clarity.
Sterilizer Manufacturer:
Pelton & Crane Model of Sterilizer: Problem Title:
DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature Problem Description:
DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature Reasons 1. DELTA 8 10 Error P2: Sterilizer Pressure reaches 241 Kpa before 135'C temperature
First, check the sterilizer can return the air/steam back from chamber to reservoir or not between 90C to 110C. It is very important to make sure all air will be purged out of the chamber. Only pure steam, the temperature can match pressure. If not return, check the bellow solenoid or the Power PCB board 2. If the air purging works well between 90'C - 110'C, then check the RTC (steam) sensor to make sure it is properly connected to the Power PCB board
1helpful
How can I get a copy of the manual?
Manuals are often available for download from the manufacturer.
Step 1: to find the brand and model of your sterilizer
Step 2: locate the website of that brand on the internet
Step 3: search their product and/or support pages using the model number of your sterilizer.
Aug 28, 2016 • Baby Care
Is it possible to use Aveda or other brands' bottles in this sterilizer?
The instruction manual recommends not using any other bottles, other than the ones included in the kit, with this product. This is because they can't guarentee that they will be sterilized.
2answers
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
I have nuby steam microwave sterilizer but have lost the instructions and dont know the amount of water to put in or the amount of time to put in microwave
I have this as well. Put 200ml in for 5 min. keeps bottles sertilized for 3 hours, and if you keep them in the nuby sterilizer it will keep for 24 hours. hope this helps :)
2helpful
Ive brought a avent streliser but threw thin instuctions away i dont know how long to strelise the baby bottles for in the microwave
I googled it, here's what I found from e-how. Hope works for you.
Avent Bottle Sterilizer Instructions
By Christine Lehman, eHow Contributor
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Many parents like to sterilize their baby's bottles before use. Avent makes baby feeding equipment including bottles, nipples and breast pumps. They also make steam sterilizers that can be used to sterilize these items before use.
The Sterilizer
1. It is important to be familiar with the components of the Avent sterilizer before operating it. The base of the unit has a stem on which the racks holding the bottles (or other things to be sterilized) are placed. The bottom rack slides on the stem and lies near the bottom of the unit. It is made of mesh and will allow steam to rise through it while keeping the contents on the rack. Three other racks are available: two flat mesh racks (which look just like the bottom rack) and a rack with rings to hold bottles in place. Spacers are placed on the stem to separate the racks. If you wish to have more room between the racks, simply use more spacers. A lid fits over the entire unit.
Sterilizer Use
2. To use the sterilizer, the reservoir first needs to be filled with 90 milliliters of water. Using exactly this amount is important because if you use less your sterilizer may not work properly, and if you use more the cycle will take much longer than normal. There is a line in the reservoir marked "max" that should remain at or below the water line. You can use the milliliter marks on one of your Avent bottles to measure this volume exactly. Once the water is in the reservoir, assemble the baskets in whichever configuration suits your needs (for example, use only the mesh separators if you are sterilizing your breast pump and use the bottle rings to stand any bottles up that you are sterilizing) and load them into the unit. If you have small items to sterilize, also sterilize the pair of tongs that comes with the unit. Place the lid on the sterilizer. Plug the cord into the sterilizing unit, then into the wall. Turn the Avent sterilizer on and wait for it to cycle. Although the duration of the cycle will vary from load to load (small loads take longer to sterilize), this should take approximately 8 minutes.
After Sterilization
3. Wait 3 minutes once the cycle is over before opening the Avent sterilizer. Before then, the unit is extremely hot and the steam could burn your skin. In the meantime, unplug the unit and wash your hands. Remove the lid carefully and begin removing the items from the sterilizer, using the sterilized tongs if necessary. If you do not remove the lid immediately, the items in the sterilizer will remain sterile for up to 3 hours after the cycle is complete. Once the sterilizer is empty, pour the remaining water out of the reservoir.
I need insturctions on the first years microwave bottle sterilizer...how much water and how long in the microwave..I lost my manual
If it's the Safe and Certain Microwave Sterilizer, click here and you'll see a link to the right of the picture for the instructions.
Feb 14, 2010 • Toys
2helpful
3answers
Also looking for The first years all purpose steam sterilizer ins
the one for the microwave needs to have 7 oz of water, and goes in the micro for 5 mins and it has a color changing sticker on it the lets you know that it is done
Top The First Years Baby Care Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Chaz
Chaz
Are you a The First Years Baby Care Expert? Answer questions, earn points and help others
