Question about Panasonic KX-TA824PK Phone
How to record ogm on kx-tea308 - Panasonic KX-TA824PK Phone
2 Related Answers
Anonymous
  • 4 Answers
SOURCE: OGM (Outgoing Message) setting for KX-TA616
yes u can
Posted on Feb 26, 2009
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: I have KX-TEA308 PABx System,
It initializes in 808. Try looking in the installation manual for the complete programming references.
Carl
Posted on Apr 25, 2011
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
I have been trying to change our company greeting on the Panasonic KX-T7731 and can't figure out how. I have searched all the manuals. I also wasnt sure if I need to be on a certain phone/extension to
It's not part if the phone but deoends upon which switch (exchange) you are using and also if your using an external voicemail system or on the KXTES824 if you're using the built-in AA (Automatic Attendant)
Jan 15, 2015 | Panasonic KX-T7730 Corded Phone
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
I have a problem for product KX-TEA308 err Cannot
What are you trying to do? Are you trying to connect to it using USB from PC?. Clarify on what you are trying to do.
Oct 28, 2013 | Lands Phones
I need to delete the message on my panasonic answering machine KX-T7730
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
Bought second hand i how do I change the answer phone message to mine?
Hello. I have located the owner manual for your phone and I will provide the link at the end of this response. If all you wish to do is change the outgoing message to your own, do the following:
The OGM is your announcement to the caller and may be up to 2 minute in length. If
you choose not to record your own OGM, the caller will hear a prerecorded OGM. Use
your OGM to advise the caller to begin talking after a beep is heard. For example:
“Hello, we are unable to take your call right now, please leave a message after the beep,
and we’ll return your call as soon as possible. Thank you for calling.”
Recording your OGM
1. Press .
2. The total number of (new) recorded ICM’s will now be announced.
3. Press 8 to stop playback.
4. Press 4 5.
5. Record your OGM.
6. Press 8 to stop recording.
7. Your OGM will be repeated after a few seconds. Repeat the same procedure if
you wish to change the OGM. Any old OGM will automatically be erased when
a new one is recorded.
Here is the link I promised: http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
please rate my answer. thanks. Regards, Joe
Dec 07, 2009 | Doro 830R Cordless Phone
No user manual
To record a new OGM,
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
May 20, 2008 | Cable_and_wireless CWD4901 Cordless...
Panasonic KX-TA824PK Phone Logo
172 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
