SOURCE: 2005 Toyota Sienna Sliding Door Won't Open
Have 2005 Sienna and its Driver side door was not openning. Cheap dealer fixed it himself in front of me. After opening the doors plastic assembly while sitting inside with a screw driver. Then he bent the clip towards left where the metal wire is connected. If you guys want to see what he did i would record a video and upload for you guys. Let me know at [email protected]
SOURCE: could not open driver side manual sliding door in my 2003 Sienna
need to remove inner panel.. be careful not to break panel... ck latch seems broken.. o
SOURCE: 2005 Toyota Sienna XLE - Automatic sliding door not closing.
This may or may not work depending on exactly what is wrong with the door, I cant tell what is wrong without looking at it directly however:
You can try starting with all doors closed and unlocked, keys in hand disconnecting the battery and letting the vehicle sit for 2 min or so, then reconnect the battery. Put the key into the ignition and turn it to the on position but do not start the van. Next press the button to disable the power sliding door for the drivers side, then manually open the door fully, wait 5 seconds, then close it manually fully. Press button the button again to re-enable the power sliding door, then try to use it with the automatic feature either by pulling the handle or using your remote, this may or may not work depending on if the door has somehow become de-initialized (it should work now) however if something is broken inside the door closing mechanism or door closed/open sensors, the door will continue to malfunction.
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram for Toyota car?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
right side slide door light switch on Toyota
Sienna?
http://repairhelpcenter.blogspot.com/2012/01/details-for-replacing-right-side-slide.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
To start, the noun "''rear latch switch'' is incorrect. It's actually called "Slide Door Lock". It's located on page BO-20 of the Toyota Repair Manual for the 2001 Sienna. There are two door locks on one sliding door. One in the front and one in the rear. Obviously, you want the one in the rear. The location for the "Slide Door Lock" (which also contains an electric switch) is in the rear of the sliding door located mid way up door. You can see (sliding door opened from the back) it without dissembling the door. And, the lock is made up of plastic (dirty white in color).
