Motorola Mobility Tz700 Bluetooth In-car Speakerphone Logo
A
Anonymous Posted on Feb 06, 2013
Roadster in spanish need english
Spanish mode need to be in english mode
1helpful
Spanish to english
without phone model - I can give you vague solution but here goes
find apps. in spanish it will be most likely be aplicaciones
find settings could be Ajustes in Spanish
system - Sistema in Spanish
look for Idioma e introduccion in Spanish
then look for idioma in Spanish
change from Espanol to english
Aug 15, 2016 • Cell Phones
How do I switch from Spanish to English
You can switch languages by following these instructions. How do configure the Roadster 2
Mark
Motorola Support
How do u switch it from spanish to english?
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
The answering machine announces, For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish).
Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
If you need a manual, you may download one here.
My motorokr is in spanish and i need it in english
To modify T505 configuration settings, enter setup mode by pressing and holding the Call button while powering up. The main indicator is steadily lit in green to indicate your T505 is in setup mode.
Language Options: English, French, Spanish, and Portuguese
1helpful
2answers
2helpful
Spanish to english
machine is speaking Spanish, need back to English.
hotrock, AZ
16helpful
2answers
The Phone's mode is stuck on Spanish
Press and hold the "Skip" button. I did this while the answer machine was ON. The english voice will say that the language has changed to english.
Top Motorola Mobility Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Motorola Mobility Car Audio and Video Expert? Answer questions, earn points and help others
