SOURCE: I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
SOURCE: what does the "F24" message
hello,
simple ,The "F 24 " error code is an indication of a water
temperature sensor error. There is a chance that there is a loose wire
connection on the water temperature or liquid substance
what
you need to do to fix up your oven is to check on the wiring
connection from the power supply to the panel indicator (control button ).
thank you and thanks for using fixya.
SOURCE: Oven works properly when baking. When not in use,
This means that the oven has detected a
condition it needs to check. Press "Cancel" to clear the display and to
stop the beeping sound, then try turning the oven off and on again.
If you still see the "F24," turn off the power to your oven and wait five
minutes before turning it on again. If you hear the beep or see the "F24"
when you try to bake or broil again,
These codes mean that the oven's electronic control has detected a
condition it needs to check. When you see a code, follow these steps:
Good luck.
Thanks and thanks for using fixya.
SOURCE: F24 shows on readout and oven shuts off
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls. Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
SOURCE: Thermador Model C302 Convection Oven
Hi alatfios,
This error F24 and the beeping sound is unfortunately because of a bad touchpad. The error code F24 means that the key has been stuck for longer than 120 seconds. The beeping sound that you are getting means hte button is opening and closing. Heat will cause buttons to stick sometimes. When you warm your oven up it expands the buttons and makes it so a button is being held down so you can't push any more to turn it back on. The touchpad is the glass assembly on the front. You can purchase it online and that is the only part you need. Kindly click here to purchase.
Hope it helps.
Thank you for using Fixya.
Thermador model SEC302BS/03 Unit beeps and fault code f24 appears on display, oven then does not operate?
