Question about Precor 9.1 Mode 1 Treadmill Repair Parts Eprom
My 9.1 started throwing the switch but now it does not turn on at all. Is the switch bad?
The switch does nothing when I try to turn on the treadmill.
Posted by Jerry Dodgen on
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
Der Sir;
The power switch is failure , you must Change the switch. You must be shure the some wires is Not loose, otherwise the wires will be touching the carcase causing the spark inside. Retight the wires or solder .You must inspect the main motor board and all the element around . If someone is burned or other wires is touching the carcasing producing the spaprk.
sincerely. God bless you.
ernesto cuadramanagua, nicaragua c.a.
Posted on Feb 29, 2012
Have ln85 hilux won't start some time turn key and nothing. Have replaced starter motor,ignition switch and battery still the Same will randomly not start
There could be multiple issues here and it's hard to say without really looking/running numbers - is there power (lights/dash symbols/etc) when you turn the key? Or completely dead?
If completely dead, did you see a random brake light while driving? That could indicate a bad alternator. Does jumping it start her? If so, possible you have a parasitic draw in the system draining the battery.
Ground wires are important to check, also.
Off hand, without much data to work with, mass air flow sensors can cause a no start - try unplugging this and starting. You can also backprobe to test sensor and harness for ground. This may not throw a code right away.
I see "sometime," so if assuming a start at times and others not randomly - recheck ignition switch assembly wires, follow them and see if any are loose. A friend had this issue and found the ignition switch assembly wire coming from the alarm was loose.
No codes and random starting, I'd lean wiring. Maybe retrace your steps - it sounds like you tackled the more indicative issues already.
Apr 19, 2017 | Cars & Trucks
My 99 jetta isn't blowing any air at all when I turn the ac on, or even the fans.
if I am understanding you right the fan isn't blowing anything. this could be a couple of things it could be a blown fuse, a bad relay, a bad switch, a bad fan motor, or a bad wire. I would start with checking the fuses and relay if they are all good I would see if there is power to the motor when it is on if there is power it is ether a bad motor or bad resistors if your fan runs on high but nothing else it is probably the resistors if nothing works it is probably the motor. if there is no power at the motor when there should be I would check for power at the switch if there is power going into the switch but no power coming out of the switch the switch is probably bad. if there is no power going to the switch you may have a brake in a wire if there is power coming out from the switch but no power at the fan you may have a brake in a wire if you suspect a brake in a wire you can test the resistance going throw the wire by setting a dvom to resistance and touching the positive lead to one end of a wire and the negative lead to the other end of the same wire high resistance bad wire no resistance good wire make sure there is no power going throw the wire when you test is though or it could throw off the test.
Jul 02, 2015 | AC Cars & Trucks
I have a Pontiac Grand am se 2.3 liter that won't start everything powers on but hen I turn the key to start it nothing happens not even a clicking to stay an get it t I start??
Turn on headlamps and try to start. Do lights dim? Yes= bad battery connections, low charge on battery, bad solenoid, bad starter. Not dimming? bad solenoid, bad starter switch, bad neutral safety switch, bad starter relay, bad ignition switch. Use voltmeter to see if ignition switch works, and so on.
Dec 17, 2014 | Pontiac Grand Am Cars & Trucks
My 2005 suzuki aeiro wont start.battery is good . wont turn over
what transmission,?
this can be 3 things, if it wont jump and batter is good.
bad connections at battery or starter.
1: bad starter.
2: bad (A/T shift switch) or bad M/T clutch switch.
3 bad ignition switch.
4: bad wire or connections end to and start system.
hot wire the starter solenoid, if car starts (cranks) then its 2 o 3.
Apr 07, 2013 | Suzuki Cars & Trucks
My 2005 stratus will not start, it does not click
Sounds like it's not engaged in Park completely. Try starting in Neutral. Neutral-Safety switch could be bad. Also could be other things like a bad ignition switch or wiring problem.
Nov 06, 2017 | 2005 Dodge Stratus Coupe
Ford windstar 1998 ignation won't turn over?
Without more info I am going to throw a few things at you, please disregard what does not apply.
Dead or low battery
Bad starter
Bad solinoid
corrosion on the battery
bad connection to the starter
Not all the way in park
Try placing in neutral to start
Bad ignition switch
Anti-theft system activated, lock and unlock door with key
These are not in any specific order
Hope something helps
May 22, 2010 | 1998 Ford Windstar
The cycle doesn't start, when the start button is pushed nothing happens and the machine goes dead.
This could be one of a couple of differnt things,one is the switch is bad, 2 a wire is broken - 3 the timer is bad or you have a dead short which should if properly grounded will throw the breaker or fuse
Aug 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Difficult to start -- bad kill switch?
You have 3 safety switches located on the tractor, any one of which can cause the tractor to not crank over.
I assume the deck lever is not engaged, you are sitting in the seat and you push the clutch down when trying to start?
Start by lifting the seat and disconnecting the seat switch, push the clutch in and try to start.
Start there and we'll go from there.
Regards,
Aug 21, 2009 | Craftsman Garden
06 f150 will not turn over
Neutral safety switch on the tranny?
Aug 13, 2008 | 2006 Ford F-150
Precor 9.1 Mode 1 Treadmill Repair Parts Eprom Logo
67 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
