Have two Delphi Roady XT's, two home kits, and two car kits. I have never had it plugged in to anything other than our home and car kits.
Recently one radio stopped displaying "Frequency" option in truck, and when docked in home kit "Frequency" option is there but all I can hear is static. However, if the stereo volume is cranked up I can hear the station playing faintly in the background.
I have tried resetting to factory defaults, changing frequency, cleaning, unplugging/plugging, powering down/up ... and even letting it 'rest' off the dock for weeks now.
I have another Roady XT and it is working fine in this home kit, the home kit we have in the shop, and in the truck and car.
So, is it one garbage and, I believe obsolete?
I can't believe Delphi doesn't even have repair centers for any of their products...charming!
SOURCE: Delphi Roady XT Quit Working
This sounds like the problem I posted about the a/c adapter. The radio doesn't get enough power because the scr in the a/c adapter is failing.
SOURCE: URGENT Belkin F5X007*****Please Read!!!******
same thing happened to me and I had to take the radio back to Walmart...
SOURCE: roady xt and car kit under warranty but part is obsolete
Wow, sounds like a tough break, Personally I would take the XM offer, or perhaps look at Ebay for a new dock. YOu can go throught the warranty process with delphi they usually are simple enough to deal with, but that will be a long process. Wiring it into the radio is still going to require a working dock, and most stock car radios dont have an input. Some will say AUX input or XM ready on them. Now if your car has a tape deck you might try one of those handy tape adaptors that plugs from your dock to your tape deck. You can pick those up at your local electronics store for 10-20 dollars, and they work pretty well. Hope that helps Let me know there is anything else I can do
SOURCE: No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
SOURCE: does not work when docked in boombox,not getting
the "reactivate" did not take in it's entirety, try calling sirus/XM again and see if they will "reboot it again, this time try having it the docking station within antenna "range", and both should "reboot", let me know if this fixes the problem, if not I have some friends there I can call, and we'll go from there, god bless and happy 4th......
Yes, tried this and direct plug-in didn't solve the problem either ... darnnit.
Yes, I did try direct plug-in and this did not fix it either. Disappointed.
it sounds like the one that doesnt come in clear, has a wireless fm transmitter problem. have you tried using this one on a wired fm transmitter??
