Samsung LN-S3251D 32 in. LCD HDTV Logo
Patty Posted on Feb 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung lcd volumn ok with dvd very low with tv only
The volumn when watching TV is clear but I have to turn it up near the maximum of 100 to hear much. After warming up for 20-30 min I can hear at 70-75 on the volumn scale. The volumn is fine when using my DVD player or Roku box with this tv. TV volumn at 17-20 is more than adequate when using either device.
Level 3:
  • Samsung Master 19,187 Answers
  • Posted on Feb 07, 2013
Samsung Master
Level 3:
Answers
19187
Questions
0
Helped
4339564
Points
82259
What is it connected to when the volume is low? How is it connected
5 Related Answers
Anonymous
  • Posted on Aug 21, 2009
SOURCE: New Samsung Tv High pitched hum
Don't know if people are still having this issue or not but figured I'd post what i went through to help anyone that has. My LN-T3253H tv as out of warranty when I finally got around to calling Samsung. They flat out lied about the commonality of this problem and I convinced them to at least pay for any parts. Problem is the labor of a technician would be around $150. So, I bought the new power supply from Partstore.com for around $70. Just go to partstore.com and enter your model number and look for the power supply on the page. It took 3 days to get the part. It was very easy to replace. All you have to do take off the back cover of the tv (think there were around 12 screws all around the outside and one where the A/V connections are and pull off. Unhook the plugs going to the power supply and the four screws holding the board and then replace with the new board. So far, this fixed the issue. Keep your old board in case it starts happening again. You can probably have the old board repaired to fix the original problem since so many TV repair shops are aware of the issue. I am trying to find out from someone which specific capacitor or other piece is causing the issue and plan on fixing it myself. If and when I do, I will also post that.
Make sure you give Samsung a ton of grief when you speak to them and see if they lie to you also. I had just bought two of the new Samsung LED TV's for my media room. They work great but I returned both because of Samsung's refusal to fix my LN-T3253H and I will never, ever buy Samsung products again.
Anonymous
  • 93 Answers
  • Posted on Nov 06, 2008
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Anonymous
  • Posted on Apr 01, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Anonymous
  • Posted on Dec 01, 2009
SOURCE: No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Anonymous
  • Posted on May 26, 2010
SOURCE: optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
3helpful
FUNAI WD5B-N8480ZB CONNECTED TO SAMSUNG TELEVISION VIA HDMI. WHEN PLAYING DVD NEED TO TURN SOUND ON TV NEARLY TO MAXIMUM TO GET REASONABLE SOUND
if you haven't alread, try connecting your tv with the standard RCA connectors, (for the audio) you may have to also connect the yellow video cable depeding on your system. If the audio is low level with these connectors, the problem may be the TV itslef. Aother option is to plug something else into the tv audio inputs (again you may need to have something plugged into the yellow video input. good luck
1helpful
2answers
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
I have a Samsung 46''B6000 tv hooked up to a samsung Blu ray player B-1590 via HDMI cable. During the course of watching a BR disc, the volume had to be increased all the way up to 100 (max), to be able to...
This happens on our samsung too with some dvd's.
It is not the tv's fault (in my case) but have to turn the volume button on the dvd remote up full first then adjust from the tv remote as required.
2answers
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
1helpful
3answers
Samsung lcd-tv is making a buzzing noise
I have been having that same buzzing sound. It happens when you turn on the energy saver feature on the tv setup. Just turn it off. Smooth
Volumn Control on my 36
I have to turn my volumn to 100 to hear it and the tv is 1 month old.
10helpful
5answers
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
