HTC Amaze 4G Android Smartphone Logo
Posted on Feb 06, 2013
I have bought new htc amaze and its signal goes to zero everytime after intervals of time what to do to fix it can anybody help me out plz
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
779
Points
30
The best thing to do right now is to exchange it to see if it is the phone itself.
Htc tablet pg41400 restrat problem
it might be problem with system software... i think
it wants to reload the operating system...
Htc amaze battery life
Oops, it does not have to be, at times, I meant, supposed battery failure
If the battery contacts/pins for your phone/tab are not making contact well with the battery terminals/heads...you will experience such, constantly.
If the battery does not sit/fit well in its compartment, you will still experience same as you do at present. This is because, the battery is making partial contact with the terminals/pins.
Check these; whether your battery sits well and fits perfectly in its compartment inside your phone/tab.
Check whether the terminals are contacting well
Aside of these, you may need to either replace your cellphone/tablet's battery and watch what happens.
My htc wildfire s hangs on htc logo when i do factory reset ..
Hello Ankur, making a factory reset to a HTC can stop Recovery from working as it wipped lot's of configuration data. So there are some steps to make that HTC working great again. First you need to check security state ( by pressing power+volume down buttons when starting - removing batery first is the best way). There you can find Fastboot, Recovery, Reboot... if it can't load a starting (branded or not) image, it can be flash connected to pc. I had reconfigured one of my HTC Desire S with new Viper android operating system. it's great. if you can find if it is a "LOCKED" or "UNLOCKED" and is in "S-ON" or "S-OFF" phone (as described in upper bolded font), I will can help you fixing that HTC.
2helpful
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
My HTC Amaze shut down and wont turn on or charge even with battery change
Try leaving it on the charger for a few hours and see if that helps.
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
2answers
I need to unlock my HTC Amaze 4g for free
Dont try to unlock your phone with free unlockcodes which you get from some sites.entering wrong inlockcodes will brick your phone or it will be hardlocked. so its a better idea to buy unlockcodes from any trusted online vendors.
From my personal experience i would recommend http://unlockgenie.com/.
i unlocked my HTC AMAZE 4G with their help. i placed the order and i got my unlockcode along with the unlocking instructions to my mail address. the code worked fine and now i am using my HTC with my favourite network provider
Top HTC Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Sean Wright
Sean Wright
Are you a HTC Tablet and eReader Expert? Answer questions, earn points and help others
